Pressurised MAFs
  • Pressurised MAFs
    I need to move my MAF into the intake pipework after the IC. But i have a few questions
    How do i mount it?? As the plastic ends will not take a huge force from a hoseclip
    What do I do about a dump valve? Do i stick with a recirc. and if so where do i put the pipes???
    If anyone can get some picture of their cars that would be a real help.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    I will take some tomorrow, as promised. Sorry to keep you waiting.
    Søren S2
    Audi RS4 LO550
    BTG 8:08
    www.fredslunds.dk
      What about this way
      Audi RS4 LO550
      BTG 8:08
      www.fredslunds.dk
        And
        Audi RS4 LO550
        BTG 8:08
        www.fredslunds.dk
          OK, so what about the diverter valve?? Are you using BOV type??
          Audi UR Quattro
            Diverter ??? What is that.
            BTW are you on ICQ ?
            Audi RS4 LO550
            BTG 8:08
            www.fredslunds.dk
              I will be in a minute!!
              Diverter = dump valve
              Audi UR Quattro
                Bov is here.
                Audi RS4 LO550
                BTG 8:08
                www.fredslunds.dk
                  So the MAF doesnt have boost then, only vacuum from turbo?
                  Audi UR Quattro
                    It is like this
                    Audi RS4 LO550
                    BTG 8:08
                    www.fredslunds.dk
                      Look Tom - just like my drawing I did for you!
                      If you have the maf after the turbo does that not mean you can have a dump(to air) valve?
                      S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
                        One problem with this - if the air going through the MAF gets hotter(quickly) does it make the MAF reading inaccurate?
                        On the intake side the air temp is relatively consistant - on the boost side you can get +40 deg C increase through the revs on-boost?
                        What does Mihnea say to this?
                          I only made small adjustments to the ECU. No problems. Even runs nice right after I moved it and no change to ECU.
                          Audi RS4 LO550
                          BTG 8:08
                          www.fredslunds.dk
                            BTW.
                            MAF measures the amount of oxygen passing.
                            Warn air = less oxygen.
                            Cold air = more oxygen
                            Audi RS4 LO550
                            BTG 8:08
                            www.fredslunds.dk
                              He isnt too sure as he has never mapped a car with it like this. intake temps will stay low on my car anyway. They never get above 30 degs, even with hard abuse!
                              Yes you do have to have a dump to air type DV. I do have one of these, but i hated the noise. Sounds like a ned car! Will have to get an HKS one or something with all my spare cash
                              Audi UR Quattro
