Audi S2 Monoblock caliper brackets
  • Audi S2 Monoblock caliper brackets
    I have 2 different types of rear bracket for sale.
    1st is a S2 coupe only 300mm size disc bracket for use with 996352421/422 calipers
    2nd is a S2 avant and coupe 330mm size disc bracket for use with 996352421/422 calipers.
    both 300mm and 330mm discs that are needed are audi items and are cheap from the dealer. please see pics and pm me for details
    brackets are £125 a pair deliverd
    bump
      What's the suggested setup for a handbrake?
      91 Modded 3B
      14 A6 Avant Black Edition
        Hi Steve,
        I guess you'll be wanting a set of these: -
        tn_Handbrake adaptor 001.JPG to go with a pair of these: -
        Add a few bolts, a hose and a cable and shazzamm
        tn_Rear brakes 015.JPG is what you get
        JB
        2001 996 C4 - Being renovated
        1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
          ooooohh, now I like the look of that...
            Sent you a PM!
              Originally posted by John B View Post
              Hi Steve,
              [ATTACH]38321[/ATTACH] to go with a pair of these: -
              [ATTACH]38322[/ATTACH]
              [ATTACH]38323[/ATTACH] is what you get
              JB
              Tasty
              91 Modded 3B
                Yes, Will's 996 adaptor is top notch and plug & play. The setup runs the 300x22 S4 disc, same as Paul's (S2Central's) upgrade (before trimming it to 280mm!). The effect of having 996 calipers at the front and rear reduces nose dive considerably - the car squats under heavy braking. The handbrake calipers are R8 / Lambo Gallardo ones.
                JB
                  How much are they?
                    Originally posted by andy10v View Post
                    How much are they?
                    I got the AP Racing (Brembo) handbrake calipers (new) for £312.00 delivered to me for the pair. Lot cheaper than going to Audi or Lambo!
                      i only have 3 sets of 300mm coupe brackets left now
                      i have 5 sets of avant 330mm and coupe 330mm left
                        that's about the same as a decent set of main calipers (used). is there no alternative that does not read Brembo (usually that raises the price a lot)
                          Hy did you revived my last PM?
                            Bear in mind these prices are new and you can pick up used ones at a lower price. I have looked at several makes such as the Wilwood caliper but come to the conclusion that: -
                            1. The calipers are used elsewhere on the Audi range
                            2. The weight of our cars prevents some of the calipers being used as they are for kit cars
                            3. They fit well and last a life time
                            4. Lamborghini, Audi, Aston Martin etc. don't choose these calipers for no good reason
                            5. They look great!
                            You pay your money and you take your chance. My view is that if we spend time putting on 996 calipers front and rear then the least we can do is put decent handbrake calipers on.
                            JB
                              Will,
                              Brackets received promptly and very well packed: great service.
                              John
