For sale a kit of solid(alu/steel) bushings for C4 chassis front subframe. Fitts all C4 chassis, urs4/6, 100, A6, petrol and diesel.
130 euro + shipping, including everything you see in the pic. Plug and play!
A couple of kits shipped out today. Just so you know guys.
5 kits left for direct shipping...
This is the last batch I make, so if you wan't a kit hurry up.
Anyone in need of new (so why not solid) bushes for your UrS4/6 front subframe..?
One last kit still available. Fastest one gets it.
Got a small batch of these, but I have only 5 kits left. If I don't get a bigger group buy, these will be the last kits available.
I haven't fitted my set yet, but need to soon. Can these be done without a complete removal of the subframe?
Yes, it can be done without complete removing of the subframe. Just loose the back bolts and remove the front bolts first, squeeze out the old rubber bushings and fit the alu-bushings back in. Then put back the front bolts but don't tighten them. Then remove the back bolt and remove the backmost bushings. Can be hard to get out, but they will came out with some force. Then throw in the steel bushings and tighten all bolts.
Edit. I did it like that, but with a better thought it could be easier to change the backmost bushings first when you still have the old rubber bushings in front.
