Anyone ever use one of these? I'm thinking of getting one as I will be using a dual spring pressure plate and this would hopefully make the pedal a little easier and modulation more precise.
I ended up getting a different one. The overall height of mine is 10mm more than the standard release bearing, so until I mate up the box to the block and take some measurements I won't know if this is ok. I'm hoping I won't have to re-use a gearbox spacer.
