K24R OE look EGT Gauge Faces
  • K24R OE look EGT Gauge Faces
    I've had these made to match the boost gauges that I sell. Due to the cost of the gauge & thermocouple kit ($145 + post + duty), I feel it would be better for all concerned if people source their own gauge and thermocouple kit - VDO P/No 310-153.
    The gauge kit can be found in the US at these places, among others-
    http://www.egauges.com/vdo_ind.asp?T...ion&PN=310-153 ($165)
    http://www.summitracing.com/parts/vdo-310153/overview/ ($145)
    Fitting the face is fairly straight forward, or I can offer a fitting service, including special delivery return postage in the UK, for £30 and with insured airsure outside of the UK, for £37.50 This is equivalvent to just over £20 for the labour.
    The dials are available in S2 grey and RS2 white and are priced at £25 each, delivered in the UK, £30 for Europe, £35 for RoW.
    I am going to be fitting my dial in place of the OEM Voltage gauge and fitting the OE dial's bezel and screws, to match things up perfectly. I can do this at the above prices, when a voltage gauge is supplied - a black faced dial can be used but the screws will not match the OE grey items, unless I can find some suitable paint at a local model shop...
    Where there are a few people in the same area looking for these, it may be better to group together and buy the gauges as one, to share postage costs.
    I'm just trying to find an adapter for the EGT probe to a stock lambda bung. Just about found it after a few hours' effort! Pirtek are getting me one in, so hopefully, it'll be only a few £
      Which thermocouples are you using?
        VDO one that comes with the kit...
        Found a lambda bung adaptor courtesy of Pirtek
          Fitting thread.
            Rough guide to fitting the egt sensor from when I did mine.
            http://www.s2forum.com/forum/showthr...&highlight=egt
            Need to get your version now though
              That must be a different sensor and most ABYs don't have that pre-cat sniffer pipe. Also, you want the thermocouple sticking in to the exhaust quite a bit, so having multiple adaptors isn't a good plan, hence why I got a single adaptor to do the job. Mine now sticks almost in to the centre of the DP
                I don't have multiple adapters, just one to go between the downpipe and the egt probe.
                Just thought it might help somebody.
                Are you going into an extra lambda bung on your downpipe?
                  Ah, cool
                  I have 3 bungs in the DP: NBO2; WBO2 & EGT.
                  All fitted now :-
                    Bump
                      Mid week bump on these If anyone is interested, please get in touch
                        Bump.
                        I can look in to buying the gauges from the US, if that's more appealing to people
                          These are still available.
                          Reduced price, £20 delivered in the UK.
