Using the the gauge and faces for sale here.
I decided that I wanted to fit this in the OE voltage gauge position, next to the oil pressure and temp gauges. I have a spare set of gauges with a holder, to mock this up.
The first thing was that the bezel on the EGT gauge was different to the OE ones, so I took the bezel off the Voltage gauge and fitted that one, which was a great fit.
Next, I had to modify the auxiliary gauge holder to take the EGT gauge. This involved a hacksaw and a file, so hardly difficult.
Finally, it was just a matter of fitting it all together. When I fit it in the car with the matching gauges, it'll look completely OEM.
Next was fitting the probe, as I comes with a 1/4 NPT adaptor and I wanted to use a stock M18x1.5 lambda bung that's in the exhaust by the turbo outlet. I struggled to identify the thread on the probe but some measuring and a little guess work identified it as a 7/16-20 thread
A call to Pirtek later and I had a part on order, similar to the L series adaptors on page 9, here... an M18x1.5 to 7/16-20 male-male joiner. I believe the part number is L-18-07 and it cost about £6
I then ran a 7mm drill down the centre bore, to clear the probe and test fitted it... all fitted perfectly
A few pictures of things as they stand at the mo.
Pictures aren't the best but they show what needs to be shown...
