I have had a bit of a clear out and these are duplicate and unwanted items that may be of use to someone.
All prices are + P&P
and are subject to reasonable offers
Block Water Coolant Sockets All standard
£5.00 Each
Inlet Throttle Boost Hose no splits
£10.00
Used Water Pumps can be used for recon exchange core units.
7A/3B, ABY and ADU all genuine Audi
£10.00 each
ABY PCV Pipe Part No: 034 103 211 P
£25.00
ABY/ADU Dipstick & Tube
£25.00
ABY/ADU Water Hard Line and Vac line that runs behind cambelt
£50.00 each
Oil Filler Caps Standard
£5.00 each
ADU RS2 Hotside - It has hairline cracks, I have tried to show in picture
£130.00
Piece of rubbish RS2 Chinese Log Manifold. Nothing lines up anywhere and will need lots of faffing about with if you can be bothered!
£40.00
ABY Exhaust manifold - with a visible hairline crack
£40.00
ABY Gearbox Spacer
£15.00
ABY Dual Mass Flywheel and Sachs Clutch
£60.00
Water Rail
£65.00
ABY Exhaust Manifold with a visible crack - Aqua blasted.
£75.00
ABY Rocker Cover Aqua blasted
£75.00
£5.00 Each
£10.00
£10.00 each
£25.00
£25.00
£50.00 each
£5.00 each
£130.00
£40.00
£40.00
ABY Gearbox Spacer
£15.00
£60.00
Water Rail
£65.00
£75.00
£75.00
