Vacuum Brake Servo on RHD ABY
  • Vacuum Brake Servo on RHD ABY
    Dear Lord! What a scoundrel of a job that was on a stock ABY. I had the engine out, so it was easier but if you do it with even the head on, I'd give you a
    The problem with the ABY was the fuel lines, which after trying a few things, I had to completely reroute, bending the steel by hand...
    The end result looks better than I thought and with a few more tweaks, should be acceptable to me but the neat freaks out there would want to completely replace the lines from where they enter the engine bay, that way you could get them looking spot on amd use some fancy fittings.
    Good job. God knows why the Audi engineers came up with that stupid fuel pipe arrangement on the ABY!
    I though you cleaned that engine bay out
      I did after the pictures. That was post angle grinder.
        Thread split from this original thread.
