Hi!,
Got some bad news for you. As a previous lister has said, those part numbers are for 996 Carrera or Boxster S, NOT GT3!
I take it these are the set off Ebay.
There is a 996T/GT3 4 pot monobloc. They use a thicker disc. The p/n of those fronts are:
996 351 429
996 351 430.
They are usually red.
They do differ in dimensions. The caliper spacing is different so won't bolt onto RS2 mounts for example. Simple way to check is to measure from the front of one mounting hole to the front of the other. If its 130mm they are ordinary 996 calipers. If its 142mm they are 996T/GT3.
Obviously I don't know what you intended to buy. If I am correct, you have purchased 996 calipers advertised incorrectly as GT3 calipers. If you have paid a premium for GT3 calipers, then get back to the seller.
Hi!
The best way to identify your calipers is to PM Alistair C. He can identify the p/n's for you. He's a lovely chap! In fact, I would do that first. That way you will know for certain what they are off of. You would think a specialist breaker would know though!
I think 996T/GT3 rears are:
996 352 425
996 352 426.
In fact I thought all rear calipers had the 352 designation. You can see how confusing it gets. If one pair of calipers have a lot smaller pistons, then they are rears.
I am certain about the GT3 front. I done my homework on them.
Just got both front and rear part numbers off this site. They are the same as the Boxster (except for the 11 on the end) so yes, definitely not GT3 calipers. Lying git.
The 11 bit is the colour.
Sorry to burst your bubble, but I detect you thought they were GT3 ones.
Get the evidence first to confront the seller. He can have no defence if he is a specialist breaker. Surprisingly they often feign ignorance!
Good luck.
The chap swears they were taken off a GT3 as they were removed to upgrade to the 6 piston version.
No matter. Have tried them up on the car and they fit straight onto the carriers I already have with the Alcons, plus the hoses fit perfect. Just need to pick up the S8 discs tomorrow and they should be fitted up this weekend.
Maybe it was a GT3 look 996?
What colour are the calipers? GT3 are only read. If yours are read then they can only be from a boxster S with that part number, therefore he is lying a lot.
Still better if you did not pay premium as the carriers would have not worked.
The rear calipers will be up on Ebay soon I guess, as I have no use for them. I see they can easily be adapted to use up front by swapping the connecting pipe and bleed nipples over.
Admittedly they were just a bit of an impulse buy.... you know what it's like.
If they are black they are from a 996 Carrera 2 and as I said maybe the car was a GT3 look. I have seen a couple of them. Seller did not know the stuff I think
