Pro Mounts bearing part number?
  • Pro Mounts bearing part number?
    Would anybody know the part number of the bearings Mance used in the Pro mounts?
    Cheers,
    Mark
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    Mine are http://www.amazon.com/FK-Bearings-FK.../dp/B00BUMATKS but they are an early version so could be different.
    1995 1PissedOff90sigpic1991 USDM CQ 7aT
      That looks like them, thank you
        Ok, if anybody needs to rebuild their promounts the recipe is as follows,
        -New topmounts from Audi. Others may work, but i found these last the longest, and the mount savers are guaranteed to fit.
        -New spherical bearings, part number listed above.
        1) Press out the aluminium sleeve from the old bearing, a few sockets in a vice will do the job. Then prize out the mount saver rings from the old bushings.
        2) Press out the stock bearing from the new Audi mount, easily knocked out with a socket and hammer.
        3) Enlarge the hole in the new mount to 28-29mm in diameter with a countersunk edge. A Christmas tree bit is ideal for this task.
        4) Press the spherical bearing into the new top mount, its a tight fit so a few correctly sized sockets and a vice will be required.
        5) Bond the new bearing into the mount, you could probably get away without doing this but i found isopon works great. I used it on the last rebuild and the bearing is still set like concrete 3 years later.
        6) Push the spacer sleeve into the new bearing, then fit the mount saver rings and your done.
        Since the promounts are no longer available i have attached the measurements of the spacer in case anybody has access to a lathe...
          Thanks for that
          Did you rebuild them because they started knocking?
          Also if anyone is going to build their own I think there may have some differences depending on what dampers are used (stock, bilstein, koni). I'm not sure what part/s would be different, maybe just the spacer dimensions.
            The first time i rebuilt them i just replaced the rubber mount as it had collapsed and felt soft. This time i found the bearing had started to corrode and seize up, hence the shiny new ones. Fitment should be the same for any shock absorber, excluding coil overs or other custom setups.
              Hi mcandmar
              I like the mod you posted.
              I was looking to do the very same thing to my shock mountings.
              Can you advise on the following.
              Are you still using this mod and how is the replacement bearing doing?
              Also the standard rubbers on the mountings about how long are they lasting, have you had any problems?
              The picture/drawing of the sleeve does not show the larger lip diameter can you recall what it was.
                Good point, i forgot about that dimension. I don't think it is that critical as long as the lip is wide enough to support the nut.
                  Can you show how it looks once assembled together before it goes back on the car?
                    Here is the original pro mount with the shiny black goop holding it together. ..which eventually fell out and let the bearing rattle around.
                    vs the crusty one which was the first rebuild using the same bearing, but at the end of its useful life. I can see a 2012 date code on the rubber mount. Note the bearing is still stuck good and solid in there with the isopon.
                    The pics further up the thread were from the second rebuild with a new mount and bearing, and mount savers II fitted instead of the original savers. Only original bit is the center alloy sleeve.
                      So to make a new setup like this the only non off the shelf part is the metal sleeve you have shown the dimensions for?
                        The material I was planning to use to support/secure the bearing was BELZONA 1111NF2 super metal.
                        •High strength structural adhesive for metal bonding
                        •Creation of irregular load bearing shims and reforming of bearing housings
                        See full spec below.
                        A 2-part repair composite for metal repair and resurfacing based on solvent-free epoxy resin reinforced with silicon steel alloy. This repair material will not corrode and resists a wide range of chemicals. It is easy to mix and apply without the need of specialist tools and can be machined using conventional tools.
                        Key benefits:
                        •Multi-purpose durable repair composite
                        •Fully machinable using conventional tools
                        •Application and cure at room temperature - no hot work involved
                        •Simple mixing ratio
                        •Reduced health and safety risks as it is solvent-free
                        •No shrinkage, expansion or distortion
                        •Excellent adhesion to metals including stainless steel, carbon steel, aluminium, brass and copper
                        •Will adhere to many other natural and synthetic materials including glass and wood
                        •Outstanding corrosion resistance
                        •Excellent chemical resistance against a wide range of chemicals
                        •Excellent electrical insulation characteristics
                        Applications for Belzona 1111 (Super Metal) include:
                        •Repair of cracks and holes on engine and pump casings, pipes, tanks and other equipment
                        •Resurface of pitted metal surfaces
                        •Repair of damaged shafts and hydraulic rams
                        •In-situ flange repair
                        Belzona 1111 (Super Metal) is suitable for contact with potable water as it is certified to NSF/ANSI Standard 61 and satisfies the UK Drinking Water Inspectorate requirements.
                        Key technical data:
                        Working life at 25°C (77°F) 15 minutes
                        Time to immersion service at 25°C (77°F) 20 hours
                        Pull off adhesion (D4541 / ISO 4624) 3,240 psi (22.33MPa) ambient cure on blasted mild steel
                        Compressive strength (ASTM D695) 12,900 psi (88.9MPa) ambient cure
                        Temperature resistance 93°C (200°F) immersed, 200°C (392°F) dry
                        Bonds to Aluminium, copper, steel, stainless steel, cast iron, lead, glass, wood and many more
                        Typical applications Bonding, shimming, filling, gluing, patch repairs and many more
                        Unit size 1kg, 2kg, 5kg. Pack sizes may vary locally
                        Availability* Global
                          Yup, a trivial job if you have access to a lathe.
                            Don't forget the "mount saver" part...
                              There is another forum member working on a very similar mount saver kit which i am currently testing...
