it's me....again! I used to get knocking noise from front suspension when going over speed bumps, but I always thought it is due to my knackered subframe bushes.
I installed solid subframe bushes on Sunday and torqued everything up as it should....but noise still isn't gone. Sounds like shock absorbers bottoming, but considering I'm running less than year old Bilsteins, it seems doubtful. It happens more frequently since I've fitted solid bushes, if roads get little bit rougher it'll knock away
I had car on the ramp today and I cannot see anything at the bottom that could make that noise. Exhaust has chain hangers and doesn't seem to touch anything. Could it be gearbox hitting subframe? (I have changed gearbox mounts too).
Every single suspension bush/mount is new, new engine mounts and gearbox mounts, there is nothing left to change.
Here is a video and you can hear the noise at 3s, 10s and 13s
