Bosch OEM part numbers
This is a sticky topic.
  • europeanme
    replied
    Originally posted by predding
    No worries Mike, sorry about that. If its easy. no worries, otherwise no problem. Cheers
    No bother, not had chance to look due to other jobs taking priority....I will do this weekend
  • Robertbozic
    replied
    Hello,
    Do you have the Porsche Part Number for this MAF as I am trying to source a new one. sports betting telegram I did buy a Chinese version on Ebay but the problem persists and Viberate many people tell me it it is important to use an OEM unit. Same story I a friend told me on his Discovery ie knock off same issue, LR OEM fixed the problem. Thanks
    im also looking
  • predding
    replied
    Originally posted by europeanme
    Blimey, this is an old thread....sorry dude but the top section is what I found back in 2009 and the source was the chap called Russ. I will try and find my old part number list over the weekend and see if I still have anything...
    Mike
  • europeanme
    replied
    Hello,
    Do you have the Porsche Part Number for this MAF as I am trying to source a new one. I did buy a Chinese version on Ebay but the problem persists and many people tell me it it is important to use an OEM unit. Same story I a friend told me on his Discovery ie knock off same issue, LR OEM fixed the problem. Thanks
    Mike
  • predding
    replied
    A piece from the old yahoo rs2_list for you all:
    RS2 MAF is actually the same Bosch part number "0-280-213-017" as the Porsche 968 MAF.
    > > >Surprisingly enough, this part is cheaper when bought as a Porsche part than as an Audi part. (much higher volume as 968 than RS2). This was helpful when I "RS2-ized" my AAN S4 back in the states and was ableto source the 968 MAF for US$239 shipped to my door!
    > > >If you need RS2 injectors, same thing applies, Bosch "0280 150 984" was also used for one of the 911's, I think it was the 964 RS:.
    Russ
    I found this on the Audi NLA website....a bit confused about the MAF numbers.....
    great find...on the numbers...
    Hello,
  • YELL MAN
    replied
    Just stumbled across this thread as I was trying to source a G62 as they are NLA apparently and a lambda sensor that wasn't going to cost £200+vat from the dealer.
    Succeeded in both thanks to the Bosch numbers here.
    Basically i'm just saying thanks to everyone that shares their knowledge here. Many of us would be lost and even more skint than we already are without you.
  • mcandmar
    replied
    "Fuel Pump 3B/ABY (and S4/S6)-8A0 906 091 G -----0 580 314 068--------- £69.00 inc VAT"
    FYI just had the pump out of the S4, part numbers are 8A0 906 091 A, 0 580 453 070. The above Audi part number supersedes it but the different Bosch part number is interesting, wonder if the specs are the same.
  • mcandmar
    replied
    ABY/ADU/AAN POS Unit
    Trying to find a reasonable price for these, found them on the Bosch Motorsport site for €373
    Datasheet here,
  • s2driveruk
    replied
    3b parts list in total
    Revision: r7393, 20110519_0953
    Automotive Aftermarket Product Catalog
    AUD 361 / Coupe 2.2 S2 T quattro / Coupe [89, B3] / 2,2 / 162kW / 09/1990-09/1992 / 3B
    Service parts
    Wiring harness parts
    Low way plug connection 1 987 352 998
    High way plug connection 1 987 352 999
    Service parts
    Spark plug, Double Platinum(F 5 DP 0 R) 0 241 245 641
    0,60 mm Electrode gap
    V-belt, open flank, toothed(13 X 915) 1 987 947 502
    For AC compressor
    V-belt, open flank, toothed(13 X 992) 1 987 947 744
    For power steering pump
    V-belt, open flank, toothed(11,2 X 866) 1 987 947 776
    For alternator
    Toothed belt(STD 1176 S8M 19) 1 987 949 141
    Idler wheel 1 987 949 345
    Fuel filter, gasoline injection(F 5145) 0 450 905 145
    Oil filter(P 3314) 0 451 103 314
    Air cleaner element, engine(S 9994) 1 457 429 994
    Wiper blade Super Plus/ME3 3 397 004 366
    Wiper blade Super Plus Spoiler, set 3 397 001 899
    Wiper blade Super Plus/ME3 Spoiler 3 397 004 255
    Wiper blade Aerotwin Retro Spoiler, set(AR 550 S) 3 397 007 045
    For RHD vehicles
    Wiper blade, rear 3 397 004 364
    Wiper blade, rear 3 397 004 365
    Cabin filter(M 2017) 1 987 432 017
    Cabin filter, activated carbon(R 2317) 1 987 432 317
    Disk brake pad set; front(BP569) 0 986 461 115
    For Lucas-Girling system
    Accessory set, disk brake pad, front(AP255) 1 987 474 253
    Disk brake pad set; rear(BP783) 0 986 494 059
    Engine
    Ignition/glow system
    Ignition distributor(JH 5) -> 12/1991
    Fg.no. -> 8B..N..005500 0 237 522 019
    Distributor cap(2 405) 12/1991 ->
    Fg.no. 8B..N..005501 -> 1 235 522 405
    Connector, suppressed, ignition distributor 0 356 250 033
    Angled
    Knock sensor(KS-1-K) 0 261 231 038
    Identification: green
    Knock sensor(KS-1-K) 0 261 231 040
    Identification: brown
    Ignition coil/trigger box, combination(TZ 61) 0 221 600 050
    Voltage supply/starting system
    Alternator(N1 R 14V 40/110A) 0 120 468 088
    110 A
    Replacement product 0 986 038 300
    Alternator(N1 14V 34/90A) 0 120 469 908
    90 A
    Replacement product 0 986 036 660
    For AC compressor
    For alternator
    Starter(DW (R) 12V 1,4 KW) 0 001 108 101
    Replacement product 0 986 018 190
    Images for Product 0986018190
    Showing image 1 of 1
    Starter battery(12V 63Ah 510A) 0 180 656 30I
    Fuel/air system
    Temperature sensor, coolant(TF-W) 0 280 130 037
    Altitude sensor(DS-H) 0 280 101 001
    Air mass meter(HLM-2-17) 0 280 213 007
    Control unit, gasoline injection(M 2.3) 0 261 200 484
    Pressure regulator, injection system 0 280 160 234
    Idle actuator 0 280 140 512
    Lambda control sensor(LSH-6) 0 258 003 019
    Universal Lambda control sensor(LSH-24) 0 258 986 502
    Injector, gasoline 0 280 150 737
    Shut-off valve 0 280 142 108
    Purge control valve 0 280 142 155
    Electric fuel pump, in-tank with parts 0 580 314 068
    Pressure damper, Jetronic 0 280 161 217
    Lubrication
    Cooling
    For AC compressor
    For alternator
    Motor, radiator fan(DPE) 0 130 109 238
    350 W
    Mechanics
    For AC compressor
    For alternator
    Exhaust gas system
    Bodywork
    Wiper/cleaning systems
    Wiper system, complete 0 391 000 316
    Wiper system, complete 0 391 000 318
    For RHD vehicles
    Wiper motor 0 390 241 166
    For RHD vehicles
    Wiper motor(12,0 V ) 0 390 241 167
    For LHD vehicles
    Wiper arm, right 3 398 102 306
    For LHD vehicles
    Wiper arm, left 3 398 102 307
    For LHD vehicles
    Wiper arm, left 3 398 102 309
    For RHD vehicles
    With spoiler
    Wiper arm, right 3 398 102 310
    For RHD vehicles
    With spoiler
    For RHD vehicles
    Wiper system, rear, complete 0 392 810 074
    Wiper motor, rear 0 390 201 514
    Wiper arm, rear 3 398 102 366
    Lighting
    Bulb, main headlamp(12 V 60/55 W H4 Plus 60) 1 987 301 040
    Bulb, main headlamp(12V 60/55W H4 PURE LIGHT) 1 987 302 041
    Bulb, main headlamp(12V 60/55W H4 Plus 30) 1 987 302 042
    Bulb, main headlamp(12V 60/55W H4 Allyear) 1 987 302 043
    Available while stocks last
    Bulb, main headlamp(12V 60/55W H4 Xenon Blue) 1 987 302 045
    Bulb, main headlamp(12 V 60/55W H4 PURE LIGHT) 1 987 302 047
    Bulb, main headlamp(12V 60/55W H4 LONGLIFE DAYTIME) 1 987 302 048
    Bulb, main headlamp(12V 60/55W H4 Plus 60) 1 987 302 049
    Bulb, driving lamp(12V 55W H1 Plus 50) 1 987 301 041
    Self-service pack
    Bulb, driving lamp(12V 55W H1 PURE LIGHT) 1 987 302 011
    Bulb, driving lamp(12V 55W H1 Plus 30) 1 987 302 012
    Bulb, driving lamp(12V 55W H1 Allyear) 1 987 302 013
    Bulb, driving lamp(12V 55W H1 Xenon Blue) 1 987 302 015
    Bulb, driving lamp(12V 55W H1 LONGLIFE DAYTIME) 1 987 302 018
    Bulb, driving lamp(12V 55W H1 Plus 50) 1 987 302 019
    Bulb, fog lamp(12V 55W H3 PURE LIGHT) 1 987 302 031
    Bulb, fog lamp(12V 55W H3 Plus 30) 1 987 302 032
    Bulb, fog lamp(12V 55W H3 Allyear) 1 987 302 033
    Bulb, fog lamp(12V 55W H3 Xenon Blue) 1 987 302 035
    Bulb, fog lamp(12V 55W H3 LONGLIFE DAYTIME) 1 987 302 038
    Bulb, parking/position/side marker light(12V 4W T4W PURE LIGHT) 1 987 302 207
    Bulb, parking/position/side marker light(T4W LONGLIFE DAYTIME) 1 987 302 287
    Bulb, front turn signal lamp(12V 21W P21W PURE LIGHT) 1 987 302 201
    Bulb, front turn signal lamp(12V 21W P21W LONGLIFE DAYTIME) 1 987 302 280
    Bulb, rear turn signal lamp(12V 21W P21W PURE LIGHT) 1 987 302 201
    Bulb, rear turn signal lamp(12V 21W P21W LONGLIFE DAYTIME) 1 987 302 280
    Bulb, rear fog light(12V 21W P21W PURE LIGHT) 1 987 302 201
    Bulb, reversing light(12V 21W P21W PURE LIGHT) 1 987 302 201
    Bulb, stop lamp(12V 21/5W P21/5W PURE LIGHT) 1 987 302 202
    Bulb, tail light(12V 5W R5W PURE LIGHT) 1 987 302 204
    Bulb, tail light(R5W PURE LIGHT) 1 987 302 237
    Bulb, rear fog light(12V 21W P21W LONGLIFE DAYTIME) 1 987 302 280
    Bulb, reversing light(12V 21W P21W LONGLIFE DAYTIME) 1 987 302 280
    Bulb, tail light(R5W LONGLIFE DAYTIME) 1 987 302 284
    Bulb, number plate light(12V 4W T4W PURE LIGHT) 1 987 302 207
    Bulb, interior light(12V 10W PURE LIGHT) 1 987 302 210
    Electrical installation
    Turn signal flasher 0 335 200 038
    Not for trailer operation
    Turn signal flasher 0 335 200 041
    For trailer operation
    Actions
    Convenience
    Heating, complete 0 141 210 010
    Safety
    Control unit, airbag(AB 1) 0 285 001 021
    For LHD vehicles
    Suspension
    Brake actuation/control
    Brake master cylinder(MC1220) 0 986 480 943
    Driving safety systems
    Control unit, ABS(ABS 2 B 2) 0 265 103 033
    Hydraulic modulator, ABS(ABS2 WSG) 0 265 200 012
    Front axle
    Repair kit, brake caliper without piston, front(RH015) 1 987 470 023
    Brake hose, outer, front(BH078) 1 987 476 230
    Brake hose, inner, front(BH120) 1 987 476 406
    Rear axle
    Brake disk, rear(BD883) 0 986 478 986
    Brake hose, rear(BH008) 1 987 476 009
    Drivetrain
    Clutch
    Master cylinder, clutch(CM120) 0 986 486 015
    Slave cylinder, clutch(CS118) 0 986 486 532
  • s2driveruk
    replied
    Alex, you're a star. Can you confirm the temp sensor on the rear of the head (G62) is 034 905 379B as on the OP, its showing as something else.
    David
  • Conan
    replied
    Hi,
    I have seen at different place that a lot of people were searching for part number and they find difficulties to find it.
    I appreciate this kind of work,.....
    replied
    Mcandmar,
    Great link for all.
    Thanks.
  • Nuvo
    replied
    Originally posted by mcandmar
    Useful part numbers on page D39 to add to your list...
    Here's page D39 on it's own for those in need of instant gratification.
  • mcandmar
    replied
  • Piefke
    replied
    Here is a link whit rotor and other pics:
    Audi 100 online - die Homepage rund um den Audi 100 und 200 des Typs 44 -Geschichte, Daten, Technik, Tips & Tricks, Bilder und vieles mehr -
    You find the pic of the 11mm rotor by "Verteilerfinger Audi 200 20V turbo"
    Piefke
