Any Skoda gurus? Door wont open / elecy windows no worky
  • mcandmar
    • Apr 2004
    • 5118
    Hi all,
    Run into a few problems with our 2005 Fabia VRS that i could use some help with. Basically the front passenger door refuses to unlock. Managed to figure out the central locking motor is not working on that door, when i use the lock or unlock function on the key i can hear the motor clunk in all the other doors, just not the front passenger. Looking in vagcom its status is "Safe" so it appears to be stuck in the dead locked position. And obviously the controller and sensors are somewhat working if it knows that.
    Had a go at removing the door card and gave up as there isnt space between the door and dash to unclip and remove it. Cant get at the wiring on the A pillar either as glove box and trim refuse to come out with the door closed >.<
    2nd issue is the electric windows dont work, started as an intermittent problem but now are totally dead. They have been dead for a few weeks now so i dont know if that problem is related.
    Also tried removing the comfort control unit and checked for dry joints, everything looked fine. Checked the drivers side switches with a multimeter and wiring diagram and appear to work fine for the up/down and half way position.
    I have a suspicion the problem may be the wiring connectors on the a-piller, but until i can get the door open i cant confirm.
    So does anybody know anything about these vw comfort/control units? Or how to unlock a stuck door on a Skoda or any VW?
    Cheers,
    Mark
    (modern cars are a ball ache)
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
