2.3 20v 7a rattle (I’m out of options)
  • 2.3 20v 7a rattle (I’m out of options)
    Hi all,
    I’m hoping someone can help with getting to the root cause of the rattle on my 1990 pre March 2.3 20v 7a CQ. I’ve exhausted all the historic threads on here and other forums, and I’m at a point where I’ve pretty much run out of ideas. The actual issue I’m having is a nasty rattle at around 1100rpm with a simultaneous cam belt slap between the cam sprocket and water pump, as well as between the idler and cam sprocket. I’ve located the noise at the distributor by listening through a pry bar. The same kind of noise is present at very very low volume above and below 1100rpm and not as aggressive. It’s only audible through the pry bar at the distributor as well as the valve cover. You can hear the very loud noise at 1100rpm at the valve cover through the pry bar but it’s not as loud as at the distributor.
    I’ll detail the journey below in chronological order. Some things I’ll mention won’t necessarily be relevant, but I’ll include them just to paint a full picture. I’ve paid very close attention to vacuum leaks, replaced a lot of hoses, crankcase breather etc etc and the car drives beautifully. It pulls where it should and doesn’t misfire.
    When I bought the car it was well over due a cambelt change, so that was the first job on the list. The noise wasn’t present before doing the cam belt job. Within that job I changed the following:
    Cam belt - Gates 5182XS
    Water pump - SKF VKPC 81606 (only one available at the time. Would like to change it to a Hepu pump)
    Crank pulley - Chef’s
    Cam shaft oil seal - Elring (maybe Corteco, can’t remember)
    After I changed these, the noise was bad and was present maybe from 1100rpm to 2000rpm (ish). This is going from memory 5 months ago, but I do recall it being worse than it is currently. I’ll note here that I can’t remember the point where it did get slightly better and sit pretty much at 1100rpm only, +/- 50rpm.
    Phase 1
    I thought it would be the obvious distributor gear and end float issue. I removed the distributor and the plastic gear was intact but split, and there was excessive end float. I bought a metal gear from Ultra Automotive
    https://ultra-automotive.co.uk/new-d...2019-uk-stock/
    They supplied me with various shims to dial in the end float. I did the replacement, shimmed within spec and the noise persisted but the pitch changed. This makes sense going from a plastic to metal gear. I re-shimmed the distributor around 4 times and there was no change every time. The rotor arm that was fitted was loose, so I thought that might be the issue so I sourced the correct arm which push on firmly and no change. I also changed the cap for a Bosch one. I sent the distributor to Ultra Automotive for them to check the condition and refurb the internals if necessary, but they reported it was in working order and the end float was correct. I bought a second distributor which was untouched, plastic gear and end float within spec but there was no change whatsoever. At this point, I’ve pretty much ruled out the distributor as the issue.
    Phase 2
    The next theory was the cam chain being slack. I ordered a Febi chain and once installed it was obvious the previous chain was somewhat slack, but not excessive. While I was there, I changed the tappets for INA 68g 420002210 (1911043038).
    This all made the top end lovely and quiet, but the noise and cam belt slap was still present.
    Phase 3
    I’d run the car for abit at this point, maybe travelled 50 miles or so driving it on the weekends and started to wonder if cam belt tension was the issue. I stripped the front end down and after removing the cam belt cover I noticed the belt had walked towards the engine. So much so that it’s put a groove in my valve cover. I noticed that the lip on the crank pulley had completely come off. I’m not sure what happened first, the belt walk pushed the lip off, or the lip came off allowing it to walk. Regardless, Chef sent me another one with some spot welds on the lip this time. After replacing that, I tensioned the belt correctly, too tight and slightly too loose (safely) for testing. I noticed that the noise did not change, although the belt slap did, which I’d assume it would do. It did not fix the slapping altogether though, just changed it.
    Phase 4
    Clutching at straws at this point, I thought maybe the idler was the culprit. I had intended to change it on the original belt change but it wouldn’t shift so I left it. I removed the belt and spun the idler by hand and it did feel stiff but not rough. I thought maybe it was creating drag and causing the belt to slap. Something I found interesting is that it was the incorrect idler that was fitted. It was a 68mm idler rather than the correct 74mm idler. I used the INA 22009601. Installing this made the natural tension on the idler to cam sprocket side feel much better. After this was all done, the noise may have changed ever so slightly, although it may be me just hoping it had changed, so let’s just say there’s no difference at this point.
    This was the last thing I tried and I’m pretty much stuck at this point. The only other area I can think it might be is cam shaft end float related. Although not a thorough test, I tried measuring the axial end float at the cam sprocket with a DTI. I say this isn’t a thorough test as the belt was still fitted and tensioned. I’m also not clued up enough to know if the end float can be measured this way, or if I have to removed the valve cover again and measure inside with the belt removed. The result of the measurement was dead zero. Again, if I can take the measurement externally like this, I understand the belt tension may not allow me to do so.
    I can’t think of anything else to add and I’m pretty sure I’ve covered everything I’ve done so far. Maybe the last things to note is that there was no visible wear on the cam shaft gear that meshes with the distributor gear. It does instinctively feel like this is the exact point that the noise is coming from, but like I said, I’m really not sure at this point. I really can’t tell if the issue is elsewhere and travelling back to the distributor. The cam oil seal also isn’t pushed all the way back as far as it’ll go. It sounds like I’m saying it’s incorrectly seated, what I mean is I installed it flush with the valve cover with space behind it. So, I’m fairly confident the positioning of that isn’t causing an issue, if that’s even something that could cause cam shaft end float issues.
    I’d be extremely grateful for any input from anyone. I’ve owned the car for 5 months and I’ve been chasing this issue pretty much from day one since doing the cam belt job. It’s even more discouraging to know that it hadn’t had a belt changed in 10 years, it was very very loose and the incorrect idler was fitted, yet it didn’t have this nasty rattle noise!
    Thanks,
    Reece
    I would re do the timing belt with a new water pump and check that your vibration damper and cam sprocket are running true using a dial gauge. Might just be a faulty water pump.
    Silver RS2 Project
      Thanks Dave.
      Changing the water pump was definitely something I was considering so I might just get one ordered to rule that out. Good shout on checking if the cam sprocket and dampener are running true. I’ll do those checks this morning and report back!
        One of the pulleys is off true for the belt to be moving out of line. Just hope its the water pump as thats the cheapest fix. I have a spare NG crank pulley here with the damper still attached. Not sure if they are the same as 7a?
        Silver RS2 Project
          Do you get the feeling that the belt walk that happened and the ‘distributor rattle’/ belt slap are all linked? I am struggling to get my head around what’s coming first in all these issues. Something being off true does make perfect sense for the belt walk so that really does need addressing as well doesn’t it.
          Thanks, from what I recall, NM and 7A are the same but I’m fairly sure NG is a different part number. I’ll double check ETKA to see.
            If one pulley is running off true its going to upset the whole engine balance
            Silver RS2 Project
              I’ll also see if I can get some footage today of the noise with good audio. I realise that ‘rattle’ is a pretty vague and broad descriptor.
                So I’ve taken an axial and radial reading of both the cam sprocket and harmonic balancer. The radial measurement for the cam sprocket isn’t going to be massively accurate as I’ve had to take that on the face of the belt, so belt thickness consistency is something that needs to be factored in. I’ve cleaned up the harmonic balancer as best I can to get the most accurate reading, though it is still pitted to a point.
                Cam sprocket
                Axial run out 0.09mm
                Radial run out (measuring on the belt) 0.11mm
                Harmonic balancer
                Outer edge axial run out 0.22mm
                Inner (surface inside the rubber) axial run out 0.22mm
                Radial run out 0.15mm
                The axial run out of the outer surface and inner surface are both at the same rotational position, so in my mind this would suggest the rubber hasn’t started detaching.
                Water pump
                Axial run out 0.12mm
                I’m not sure what’s considered within tolerance for these, or anything that isn’t 0.00mm is an issue. Let me know what you think.
                Edit: I’ll also note that all of the mating surfaces were cleaned so I’m pretty confident it’s not that there’s debris causing a tilt.
                  Ok so here’s a video of the cam belt slap while I’m revving it. This is probably the best it’s been since changing the idler and re tensioning the other day. You should be able to hear the rattle/ grumble just as I’m revving, and then again as the revs drop.
                  https://youtube.com/shorts/p0BqwwAk9v4?feature=share
                  This video is more for the audio as you can probably hear it better with the phone above the engine.
                  https://youtube.com/shorts/v7gdHP672qE?feature=share
                    I can't find any run out max tolerance data for our cars. Your figures don't look too high to me but maybe a good machine shop could advice. What i do find unusual is the belt flapping about in the video. Almost as if the belt has stretched in one area.
                    Silver RS2 Project
                      Thanks for taking a look Dave. I wasn’t able to find any specific info either, however I did come to the same conclusion after looking for info and don’t feel like the run out is considered too excessive. I will try and seek a second opinion though.
                      It is abit of a weird one with the belt isn’t it. In the video it looks like it’s slapping on the non-tensioned side a lot more, although I have seen it slap on both sides when the belt is looser. That is literally a brand new belt as well. I used the Gates belt on the original cam belt change, then after it walked I installed another new Gates one for peace of mind. That belt’s probably seen 5 miles of driving.
                      I'm not sure if I’m overthinking it, but I do wonder if there’s an issue elsewhere and at ~1100rpm there’s a resonance of some kind which is travelling through to the belt causing it to slap at the same time as the top end/ distributor noise. Or, there’s something up with the pulley system which is transferring an imbalance or resonance through, up the cam shafts and ending where the cam shaft gear and distributor gear mesh. Honestly, I just keep going around in circles with it!!
                        Have you glued the rotor arm in place? They should be on these, or they can walk off the shaft.
                          Thanks for the suggestion. I haven’t glued the new one on, but the other completely stock untouched distributor that I tested has its original rotor arm on that’s pressed/ bonded on ( I wasn’t able to pull it off when I tried). That’s actually what I thought the noise was originally but I've ruled that out after trying the untouched distributor.
