Custom hotside
  • Acidburn
    replied
    I'll upload some video's tommorow of the car driving, its all custom, its a vw caddy running 4wd, custom ecu, side exit exhaust, and a 2.8 vr6 lump (was a later multi valve lump iirc but he switched back to the earlier one)
  • AndersS2
    replied
    Uniqe, thats for sure!
  • speeding-g60
    replied
    Wtf?????
  • quattro84
    replied
    Lol!
  • Acidburn
    started a topic Custom hotside
    Custom hotside
    right he was the problem ,i needed a large turbo with quick spool ,for air effiency which they don't make , as this turbo is/or was a geniune garrett gt40 4intake , problem was the hotside it was too laggy due to size of I , 1.14 t4 twinscroll , so after searching for another hotside//but smaller they don't do one , so next option chop the buggar , yes its cast , but its cast steel with nickel contnt so can be welded ,,, so after chopping a large area off , and useing spring high tenile steel 5mm thick ,i knew it would work but how well was another story , anyway 4 hours later , it was time to try , bare in mind ,when first fitted I had major turbo lag and showing 5000rpm before boost came in , after customizing the hotside I'm in boost at 2600rpm ,lol with no surge and will pull clean to 30psi , mental , but I dearnt risk trying to tunie anymore as I'm on stock headbolts lol ,, no point in buying exspensive pistons/rods/bolts etc , long as its tunied its fun ,,, its when you get greedy and go that bit more then somert jumps out of the engine ,pmsl ,,
