It would be a crude solution but perhaps a 3bar fpr installed in the rail would be an easy way to get the presure back to 4bar, at least if you are going back to stock injectors. Might even be a VAG drop in .
Looks like its the maf load and rpm with a 3000rpm threshold for the lambda if I have understood it properly. Presumably there is no advantage to testing at the higher rpm allowed in the MOT as the load will be higher than that at the lower 2500rpm limit. Its a bit odd that they have that spread!
I have asked the previous owner to check if they have the standard injectors, I've got all fine her and toes crossed
Does the CO reading go hand in hand with the AFR? Could it be 14.7 AFR but high CO?
The only difference betwwen the dyno and the MOT test is that for the former it is effectively being driven whilst for the latter it is stationary!
So what are the parameters for closed loop operation and what does the ecu monitor? That would be useful to know.
What would be the solution to the increase in fuel pressure from the 044 without factoring it from mapping? Increase in return line diameter, adjustable fpr or something else? I have read something that suggests the fuel rail return lines are different sizes on the S4/S6 which is the braided/rubber difference. However the S6 got the rubber one which is supposedly larger anyhow.
Could it be something to do with the injector pulse/duty holding off the closed loop? The injectors are quite large at 630cc @ 3bar (this increases as it's 4.2bar in my car)
Also the car was mapped without a wideband as they opted for EGT
I could be chatting plop though
I reduced the fuel pressure earlier and it got down to a level which would pass UK emissions, I used a 1:1 sytec adjustable unit....... obviously this masks the issue and could not be driven like that, it was just my intrigue
After the MOT you'll know if it's the mapping or not. If it is, you need to get a standalone or ... prjmod and someone to map it.
I can sell you a standalone pnp kit (ecumaster based), there are other ecu's as well which will drop in.
No. If the mapping was right and is now wrong it’s because something has changed with the hardware.
This is now the Millon dollar question of has it ever passed a UK MOT legitimately on emissions, if I knew this it would make my job much simpler
An Audi tuner (don't want to name drop) from "up north" has suggested the raised fuel pressure and 630cc injectors are quite probably a large factor in the rich running
MRC have completely washed their hands of these engines now
However the Dyno printout suggests closed loop was functioning
Which says absolutely nothing about the MAF.
You should compare block 000 values between one MAF and another. Also "known working" means nothing, unless it's been bought in the last 5 years it's probably junk
As I’m working away at the moment I sent him the MAF from my coupe which is fairly new, the tune is similar and the car just passed an MOT.
Think that particular brand was discontinued leaving only Chinese knockoffs!
The plan was just to put the car back to stock injectors and run the prjmod just to get past the emissions for the mot test here rather than attempt to map it.
I appreciate that would give someone with the skills, equipment and experience to map the ecu more easily than before but I suspect like most people on here, its not something I would be comfortable with. In fact I haven't seen any reports on here outlining peoples experiences good or bad or perhaps more importantly for beginneers the processess involved even though it is fascinating!
