Bought an oil catch can on Ali with 15mm inputs, and decided to put it near the exhaust to keep it rather hot.
My fresh electronic fuel injection works really nice, sound is good too.
As a result - I have returned all the horses (390kgs of air/3 = 130ps). Fuel consumption is the same, but it seems to me that torque is little bit higher due to electronic injectors with 192cc capacity and another time of cycle injection.
Audi 90 B3 Quattro Special Edition 292/700 RU
Guest replied
Guest repliedJust wanted to make it rather clear.
So...started collecting and making parts this June.
Installed in couple of weekends.
Next is making 3D model of “hidraulic” handbrake for using in winter competitions. Stock handbrake is not so convenient to use while driving fast on the track. So I have to make an adapter for vertical handle and so on.
Impressive stuff
I admire the motivation and commitment
- 1 like
Guest repliedA lot of work: Fuel ramp
Searching for injectors
Searching for MAF sensor
3D printing of adapter from Honda air filter to MAF sensor
Welding parts
Making fuel hoses
And many more
- 1 like
Guest repliedfiledata/fetch?id=2070593&d=1571062389&type=thumb
filedata/fetch?id=2070594&d=1571062389&type=thumb
Two more pics of intake.
As you can see - I have used Honda Integra DC2 air filter, fuel ramp with external fuel regulator, idle controller in external body, and other things.
2 Photos
Guest repliedLittle update.
Finally assembled all the sensors, and made calibration.
Now my engine bay is looking like that.
filedata/fetch?id=2070588&d=1571061356&type=thumb
filedata/fetch?id=2070591&d=1571061357&type=thumb
Also I have a short video about system calibration.
Now I can do diagnostics with usual K-Line adapter to OBD2 from my ECU.
Parts much more cheaper than original ones from KE-Jet system.
It drives also better, especially from 2000 to 5000.
2 Photos
Guest repliedFinally the fuel system is assembled.
Now I have J5.1 fuel injection.
Said goodbye to old KE-Jet
Guest repliedStarted to do some work with my Audi.
Gonna change old KE-III Jet to modern ECU - Январь 5.1 (which is in fact based on Bosch ECU)
The problem has appeared in fuel ramp, few leaks on welded parts.
Bought brand new ramp from one supplier, and waiting for it.
At least my car is looking like that:
filedata/fetch?id=2069473&d=1569352172&type=thumb
filedata/fetch?id=2069474&d=1569352174&type=thumb
filedata/fetch?id=2069475&d=1569352176&type=thumb
Can't do anything until that part come...
3 Photos
Guest repliedHere you can find more pics of build.
Feel free to contact me in Instagram, because I am not visiting S2Forum so often (as you can see above lol).
filedata/fetch?id=2067369&d=1566885844&type=thumb1 Photo
Guest repliedOriginally posted by Lago Blue View PostNail,
Looking forward to hearing your impressions of your new top-mounts sir, they look like they could easily be up to the job (Russian roads!) If they work well enough I can quit making my fix for the latest Boges/Sachs!
Guest repliedOK
Lets go
After a year I have chaged my City to the middle of Russia - Yekaterinburg. 2400 kilometers of my way were quite nice, nothing has broken in a 27-years old shitbox!
The climate here is another, I mean that winter is snowy and frosty, and I have spent all of my spare time on ice track near my home
Check the video:
Every day of winter I have made really fun, even driving to my work
When it became warmer - I bought TA Technix low-budget non-coilovers and installed them on my turd. Lowered it by 40mm i suppose. Here you can see my custom-built strut mounts, they are still ok after almost 20 000 kilometers,or more...
Changed twice fuel pumps, installed 4-point harness belts, sold S2 replica bumper and made many other non-critical things.
Re-welded middle part of my exhaust
All the arms now have polyurethane
Now my front camber is almost 3 degrees and rear is 2.5
It is well balanced now, for every day, for track days and fun!
This summer I havestarted to work on electronic fuel system for 10V 5-cyl engine, with fuel ramp, Bosch injectors and other parts.
For example - it is my fuel ramp, made of aluminum with injectors and wiring part
IElMTRCnQ0c.jpgLast edited by NailTimVideo; 26 August 2019, 15:19.
- 2 likes
Guest repliedAfter a year of calm...I have something to tell.
Guest repliedThat light bar I was talking about
filedata/fetch?id=2036517&d=1535389786&type=thumb
Made of composite.
And sprayed black matte.
filedata/fetch?id=2036516&d=1535389786&type=thumb2 Photos
