Hello.
I am struggling to find the following parts for my 1995 Audi 80 Avant RS2:
2x Front ABS wheel speed sensor (893927803A)
2x Rear ABS wheel speed sensor (8A0927807C)
1x Idle Stabilisation Valve (034133455A)
I don't think the garage looking after my Audi RS2 has VCDS / VAGCOM.
Problem: ABS activating when coming to a slow stop (boing noise from brake pedal).
They think that one of the fitted wheel speed sensors is faulty but don't know which one.
I am told that it will be a case of removing one; fitting a replacement; see if that is the solution; if not, remove second one; fit a replacement, etc. but cannot reuse existing sensors once removed.
So, I may need four new ABS wheel speed sensors.
Problem: hunting idle when engine is warm (e.g. when stopped at traffic lights during a long drive).
They think it may be the ISV (there are no boost leaks from a smoke test).
Any pointers to where I can find these parts gratefully received.
At this point I wish I had purchased VCDS / VAGCOM years ago.
It might have saved me ££££ over the years in time spent diagnosing the cause of problems / purchasing parts that may not be required...
