Vems help needed
  • jonnaz
    • Aug 2009
    • 158
    Vems help needed
    Hello
    I have a few issues with Vems. I have an AAN Pnp v3.3. the car is a 3b pin swap has been completed. link to the project thread below.
    I have checked the timing with a strobe light using the ignition lock function. (I also checked a 0deg ignition advance). I have to set TDC after trigger to 54deg to get the timing marks to line up. i used tipex to make a mark on the fron pully at TDC and also check the timing against through the window on the bell housing. i thought the pin position on these engines was 62deg before TDC?
    The car misfires a lot between 1200 and 2000 rpm however I am not getting a trigger error at this time.
    i do get some trigger errors at other times when increasing engine speed (less sec Trigger error)
    The EGT probe also is a constant value of 1200 this isn't such an issue at the moment but will be when i start to Map the car.
    i have attached current config and a trigger log. firmware is 1.1.95.
