MAXXECU what opinion
  • #31
    Running MAXXECU.V1 Never had any issues.
    • #32
      Running MaxxECU V1 on my S2 couple.....best ecu I've bought to date !
      • #33
        What recommended tuner are people using for maxx Ecu (uk)
        • #34
          Jp@ Jnl racing did mine...very happy with the end result....car starts and runs perfectly making 650 bhp at 2bar
          • #35
            JP never mapped your car I know this because he told me .
            And this so called engine builder part time tuiner who took a 2 day course on engine calibration thinks he is a tuiner .
            My self and countless people who instructed him to build our engines on the basis he was the guy to use .
            there are plenty of threads showing the wake of distraction.
            In my opinion he his ISIS to a engine he kills them with no remorse !
            So so if you value your engine then contact Alex Clayton the director of Ultra performance Engineering who is a Maxxecu dealer.
            • #36
              I was at the dyno when it was being mapped, he definitely was there mapping. Anyhow we digress from the main topic......I had Emerald K6 on the S2 previously and it is a good ecu but if you want it to start monitoring the engine more like, eg EGT, Oil temp & pressure, fuel pressure etc and take action like boost cut, ignition retard or shut down....it starts to get expensive with additional modules etc. As previously mentioned in the thread the MaxxECU Race & Pro both come with EGT inputs. I use the car for hillclimb and when your going flat out you haven't got time to look at gauges....you need the ecu to make the decision if something is not right and it should shut down the engine to avoid damage. The MaxxECU support is superb....I was very impressed when doing an update and it went wrong, causing issues with the firmware....Maxx logged into my laptop remotely and fixed the issue.
              • #37
                Which version should I get, for street use, I guess "street"is more than enough ? Does it support aditional injection like methanol ?
                Thx
                • #38
                  Thx
                  "Street" version is only useful if you run E85. If you want to run on normal gasoline, get something that actually has knock control.
                  And this question should be addressed to your dealer!
                  • #39
                    Hello it’s hard to program the Knock sensors on the Maxxecu ?
                    That is the only reason for me to buy a Race one .
                    thanks
                    Manuel
                    • #40
                      It's easier than on EMU Black.
                      _Rubí_
                      • #41
                        Define hard! It’s not what I’d call hard work but definitely technical and it’s essential to get it right or you will most likely destroy your engine.
