Fitting Motorola sensor
  • prj
    replied
    Looks alright.
    I have fitted more than 100 of these sensors (I buy them in bulk 25 at a time, and I am on my 6th set), and when you have that quantity, then a simple and solid solution is the best for me - only requires one cable tie.
    And so far I have not had issues with any of them coming loose.
  • -ice-
    replied
    I made it this way...
    does not win a design Price, but it's very solid.
    Regards
  • Matzerm1
    replied
    here the picture..
    and you can use the MPXH6300 = 300kpa or MPXH6400 = 400kpa..
  • pasbogdan
    replied
    Originally posted by andy10v
    3 bar map sensor with an almost identical output to the bosch one, but for £25 IIRC.
    3 bar or more
  • Thuppu
    replied
    There is a zip tie behind the sensor...
  • a4kquattro
    replied
    can't tell from that pic, but are you tying it to the plastic cradle? looks ok, mu only issue would be if that sensor is allowed to bounce around which could snap off the solder joint on the legs.
  • martinws
    replied
    Nice and tidy. Pink wires are a lovely touch.
  • Matzerm1
    replied
    You can see of page four a elektrical circuit,
    Matthias
  • andy10v
    replied
    Originally posted by Ruffiano
    now why should we fit one?
    replied
    Similar to the 3 Bar Freescale MAP sensor that EFI Express sells
    http://www.efiexpress.com/catalog/pr...products_id=82
  • andyg plym
    replied
    Looks very neat like that, if they are more reliable than my vmap I may follow on.
    Prj did you receive my pm ?
  • Ruffiano
    replied
  • prj
    started a topic Fitting Motorola sensor
    This is how you correctly fit it:
    That is all.
