Caliper won’t bleed
  • #31
    I would bleed it again now, and check your abs sensor is within spec using a multimeter, around 1000 ohms, I think.
    • #32
      Could it be the brake bomb .
      • #33
        Is the brake bomb linked to the abs unit?
        • #34
          I'd do a two man bleed work furthest from master cylinder and back... Do this a couple of times with the car lifted in axle stands..
          • #35
            I would recommend the sealey pressure bleeder or if you have a compressor the ones that suck the fluid through from the caliper as it makes it much easier
            • #36
              Been driving it all this week and it’s working fine now.
              Not pulled once towards left or right.
              Il bleed all 4 calipers if it happens again.
              Thanks for all your advice.
