Porsche Brembo's upgraded - Excessive pedal travel S2 coupe ABY
Check bleeding again,or the pump itself.I have 8 pot calipers on the front and 4 pot on the back and stock master pump still pushes enough brake fluid to keep the pedal in the upper region.
Evening guys, girls.
Trying to figure out a few problems since having my brakes upgraded to the 996 Porker refurbished upgrades supplied by Albert.
Brakes, discs and fluid have been changed, brakes when pushed hard are immense but there is travel to get to that stage which is a little worrying..?
Has anyone else found this, would the original master cylinder not be up to this type of upgrade and if so, can people recommend a replacement or point me in another direction??
Thanks in advance,
Audiudo
