Hey guys,
i have lost the pin of the ignition switch which switch the ignition / 86s on when the key is in.
Does somebody has maybe the dimensions of this pin or a source of a new one?
This pin only the C4 automatic is using. Manual transmission has not the extra pin - reason I don’t know.
Ignition switch removed - you can see the hole/bore in the middle?
This picture I got how the pin shall look like:
Thanks in advance for any help in regard of this topic :-)
/edit:
Shows some better pictures but not details about the pin
Manual transmission:
Automatic transmission:
/edit:
