I bought (from Olli of the german typ44 forum) a relay set that will change the lights from sending the full current through the stalk to through a set of relais. Mounted a similar set in my typ85, worked plug&play.
so I mounted this one: no lights and auto check complaining. When I measure voltages, there is 12V on the relais, but the signal that should close the relais (so coming from the stalk) is only 1V (high beam) or 0V (normal beam). Which raised the question how the ligjts function in an ABY? So maybe not just a simple switch?
