Hi guys
What cabel do you use when you wat to connect the goes to the ignition but when you turn of the ignition it cuts the power.
Its for my ECU. I dont want constant + power.
Best regards
I found a thin blue cabel from the igniotion that should be good to go. Can somebody give me a hint on the relay that uses the blue cabel to the ignition ? Relay number.
