Remind me!
  • GT500
    replied
    I am just sorting mine at the mo,
    same codes, but not the boost exceeded,
    I have a new Lambda on as well!!
    NOt had them back since I upped the spring tension on my HKS bov, must have been sucking some air.
    I am thinking they throw the two codes if you have some unmetered air in there...
    replied
    SURE you haven't got an air leak ?
    Reset the ECU to clear the faults - maybe thats some old faults in memory...
    Fresh lambda is always good if its due a change.
  • Crawford_S2
    started a topic Remind me!
    Remind me!
    Right going through the the fault codes again yesterday, my mind wandered and for a brief moment i remembered what life was like before i knew what a folkin fault code was
    pulled the usual really helpful ones that mean it could be anything!
    561 mixture adaption
    537 lambda
    544 max boost exceeded
    No i haven't got a ferkin boost leek, yes i have cleaned the maf, lambda coming tomorrow and then i am just going to buy bits till the car is fine again.
    Just wanted a few of you to remind me why i keep this money pit and don't go out and get another mk1 golf on sidedrafts
    BTW ipa didn't fix the fault but it goes well with ice
