Elecric windows stopped working
  • Elecric windows stopped working
    All four of my electric windows have stopped working on my s2 coupe.the electric mirrors still work and the sunroof. I have noticed that for a few weeks that the windows wouldn't work when you first start the car, but would work after a minute or two,now they have packed up all together.Aircon not working ether so I could do with some advise,
    maybe one of the relays perhaps? theres a double relay for the elec windows, i know thats used for the sunroof also but it is double size so maybe is one part of it thats gone??
    i have a couple of spare window relays if thats the problem
    Ant
    91' Coupe quattro 20v - project
    KW V2s and other goodies
    now gone
    03' BMW 330CI - Sold
    08' A5 Coupe 3.0l tdi quattro - Sold
    57' BMW 525d M Sport Touring
      Chears Ant , but I have no idea where the relay is located or how to check it.
        If its the same as the sunroof, it should click when you try and close an already closed sunroof?
        Might help you locate it.
          Just had the same problem in two RS2s in our Club...(one is mine)
          Problem resides on the relay (wich is not a proper relay) N° 363 (if i remember well)
          that controls the eletric windows it's longer then the others so very easy to locate.
          Location (LHD) unerneath the tray on the driving side.
          Take it out bang it gently on an hard surface then plenty of contacts spray and...
          Voilà job done!
          Stefano
          http://www.audisportclub.com/
            Had a look at the relays under the dash,and I could not see one with the number 363 on it,my car is a 3b coupe,which may have a different relay. Can anyone confirm the location and relay number on aright hand drive 3b.If it relavent the electric mirrors have also now failed, but the sun roof still works
              iirc its the biggest one under there, you can't miss it because its so big. Try the one out of alex's old 20v in it as it should be the same.
                Its twice the size of the other relays, kind of a double one.
                  My car, (92) on the right
                    Martin's car (91?) Over the back
                      On mine its kinda just hanging around up there, along with the thermal fuse.... Ya cant miss it though really at that size lol
                      Audi A4 1.8Tq
                      VW Passat 1.8T RIP
                        Brilliant,many thanks guys
                          did that solve the problem?
                            I took out the relay and cleaned the connections,ect, as suggested but it hasn't cured the problem .so I am going to try another one.
                            • #15
                              Just cleaning the contacts didn't work on mine either - so I resoldered a couple of knackered (dry) looking joints and that solved the problems.
                              Ck.
                              Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
