Intermittent Electric Window Issue
  • johne
    replied
    Originally posted by Jas11n
    John
    replied
    Originally posted by sidrick
    Jas11n, that sounds exactly like my issue, especially since it has only started in the last month, but was fine over winter....Does anyone know if they're still available from the dealers?
    In the short run, replace the 20A yellow topped thermal fuse with a 20 Amp (yellow) spade fuse. If it blows when you move a window or the sunroof, you have a wiring problem that you need to sort. If nothing happens, i.e. the window and sunroof function normally, even after the car heats up, you are done.
    replied
    Originally posted by johne
    Yes, it's a double size relay, 287 in your picture. John
    Thanks. Any confirmation of the PN? 441959257D or ??
  • sidrick
    replied
  • Bryant
    replied
    Well
    I also have small little cheaper looking thermal fuses in the are under the driver’s knee on the relay boards that may be the cause of the fault.
  • sidrick
    replied
    Thanks everyone
  • Jas11n
    replied
    Linky
  • johne
    replied
    Originally posted by UrS4boy
    John: Is it the "287" relay in the photo I posted above? (And thanks to whoever it was that I stole that photo from). ("Right click/Save-as" is my friend )
    John
    replied
    .... but also as likely is that the contacts on the relay are prone to breaking. If you have a soldering iron, open up the relay and resolder all the contacts where they join the circuit board....John
  • johne
    replied
    Does the sunroof run through the same relay and is this a likely cause, or is there something more sinister or common afoot?
    The sunroof does run through the same relay, hence they both stop working together.
    It could be the thermal fuse as mentioned above but also as likely is that the contacts on the relay are prone to breaking. If you have a soldering iron, open up the relay and resolder all the contacts where they join the circuit board.
    There's a post on here where others have had the same problem and it's worked. Also worked for me.
    John
    replied
    Originally posted by benntenn67
    I was thinking this relay is the culprit, rather than the thermal fuse ?? http://www.s2-audi.co.uk/tech_articl...al/sunroof.jpg ...... but I have had a few beers
    Probably but the 441959257C in the photo below has been superceded to the 441959257D, under dash relay panel, position 5&6 (see second photo below the first):
    Not sure about the number on the 257C but it should be in the position of the "287" shown in this photo (the 324 is the after run pump relay, PN 447965571A):
  • benntenn67
    replied
    replied
    Perfect to demonstrate which ones I had in mind. The two small ones in the foreground of the photo.
    Thanks Dave.
    Hopefully all of this helps the original poster.
    replied
    Thermal fuse photos
    It’s a small little thin two spade relay/switch/fuse, in a cheap looking aluminum silver casing with a bit of coloured paint on the top. I think it’s made in Indonesia or somewhere unusual. The relevant photo would be so much more informative.
    Not exactly what you wanted but here are some thermal fuse photos anyway:
    from the C4 UrS4 Auxiliary Relay Panel III
    From the UrS4/S6 Above ECU Fuse Panel Call-out
    replied
    Robbed from urS4boy’s link in another S2forum thread active now, when you scoll down and see the fuseboard photos, you’ll see the little “fuses” I was referring to at the back of the fuseboard.
    HTH.
    Thanks Dave.
