Aux oil gauges fault.
It might be one of those weird spade terminals with a catch, look for a small spring or lever at the wire end of the spade.Leave a comment:
Both my oil temp and pressure gauges display full scale deflection when the car is started up.
Oil pressure read ~1 bar with the ignition switch in the first position, temp is fsd.
Anyone seen this fault condition before?
Is it possible to identify the G and the WK terminals on the pressure sender/switch by which one has the protective rubber boot? I know they are stamped on the body but I can't read them. I would expect the signal wire (G) to be the protected terminal but I'd like that confirmed if possible.
The colouring of the wires doesn't correspond to the wiring diagram I'm using.
Any tips on freeing of the spade connector from the terminal I have tried soaking it with penetrating fluid and gently prising it with a flat blade screwdriver but it refuses to yield.Tags: None
