S6 wont start
  • #16
    True but I'm interested to know if the fuel pump relay is actually working. I mean the relay could be closing but the contacts not making a circuit properly..
    • #17
      That would be good to know but the first thing to establish is whether the fuel pump actually pumps when given 12V directly. Once that is established, the health of the very important J17 Fuel Pump relay can be checked.
      • #18
        I took the fuel feed hose off and cranked the engine. I got 625ml of fuel in the container after 15 seconds. The Injectors ha power but the fuel still isn't going into the fuel rail. There is pressure at the rail but no fuel in the rail, there I fuel pressure when I pull the fuel pressure regulators out
        [SIGPIC]1997 Ur-S6 SMS Revo S
        • #19
          When you changed the rail did you connect it backwards?
          • #20
            Exactly. There is definitely something fundamentally wrong with this story.
            C4 UrS Fuel System: From the Tank to Injectors and Back Again:
            http://forums.quattroworld.com/s4s6/msgs/226410.phtml
            • #21
              Thanks for the picture, the guys that worked on my car swapped the supply and return lines around. Car starts now. Thanks for the help guys
              • #22
                FK me. You might want to consider using a better shop in the future.
                • #23
                  The forum rocks again!
                  • #24
                    Glad you found the problem
