Fuel pump.
I had same issue with an aby
did all things mentioned above with no change.
turned out previous owner fitted Chinese copy that couldn't deliver the goods
put a second hand v6 one in as I had it and ran fine
Misfire issue!
Well I’ve cleaned up the MAF connectors and it’s been fine the last few days. Hopefully that’s fixed it but it was intermittent before, so only time will tell.
Thanks for all the help and info guys! Much appreciated!
Read this thread, do a leak test too.
That bloomin MAF connector!
https://r.tapatalk.com/shareLink?sha...1&share_type=t
Originally posted by bazburnMAF...have exactly same on mine, unplug and replug a couple of times sorts it...HTH
My 3B used to do this all the time, finally fixed by properly cleaning the female pins in the free plug by removing them from the housing and running very fine abrasive paper between the contact surfaces. Then a final clean with De-Oxit contact spray.
- 1 like
Plenty of info under the search button for resolving boost leaks. Check your hoses and jubilee clips and do a pressure check. If the car is new to you then makes a lot of sense to start checking the mile of vacuum lines and intake hoses for cracks and cuts.
Really? Well i hope it’s as simple as that! Did that fix it for good or just a while? Is it a problem with the connection or the maf itself?
Thanks mate
Originally posted by spencerw83 View PostHow do i go about doing a pressure test? Thanks
Have you pulled the fault codes? Sounds like a boost leak. Do a full pressure test first
Misfire issue!
Hi
Could anybody help with information about a misfire & severe jerking problem on my 94 ABY coupe? It happens when you get past around 3k rpm when the tutbo starts to kick in, it misfires an the car jerks forwards and backwards. It idles and drives fine at low revs. It’s also an intermittent problem, it’s fine some days and plays up on others. It’s recently had a new crank position sensor and I’ve converted it to 2.0tfsi coils using one of Alex (error404) wiring harness’s, but that hasn’t cured it.
Any help would be much appreciated!
SpencerTags: None
