What’s this noise ??
  • #16
    Originally posted by steve briance View Post
    "Oil pressure is good, can’t hear it when driving either" that's good then.
    I've given up trying to get my distributor to be quiet, I've shimmed it so minimal play, fitted brass gear which helped a bit and neither stopped it completely. Does it more around 1700-2000rpm on the run down from revs. I guess wear on the cam gear may contribute but that's not easily sorted...
    Try replacing the cam chain , that cured my dizzy rattle
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
    • #17
      Cam chain and hydraulic lifters have been replaced, she sounds lovely :-)
      • #18
        • #19
          excellent !
          • #20
            Yeah well pleased
            • #21
              This is good to hear
              • #22
                Weirdly missed most off the end of that post. I was going to say; I've just received a crank shaft front oil seal and the next job is to fit it with the pump in situ. I ordered inlet and rocker cover gaskets as well as an INA cam chain after reading your post. I hope I get the sort of results you report as well as an oil tight engine at long last!
                • #23
                  A couple of the lifters were not working properly, easily compressed with fingers.
                  Can’t complain, them and the camchain have done 260,000 miles, mostly at higher than stock power levels!
                  • #24
                    I can wipe my brow now John, great news she's sorted now.
