Not holding boost at high revs
  • Not holding boost at high revs
    My engine actual spec is:
    K26 hybrid (same as Albert sold), RS2 EVO manifold (style), RS2 IC, 3B->AAN conversion with mafless setup. Maped boost is 1,8 bar and should hold it to the redline. Dyno result was ~400ps and ~480nm torque - shame but true. Plan is to change the IC for bigger.
    Unfortunetely after few monts of runing good it now drops boost at higher revs (0,2-0,3bar). This couses loss of about 60-50ps at the dyno (messured now 340-350ps). There are no intake leaks, timing is good, no other issues.
    What could be the reason of loosing boost at high revs? Worn out WG? Something else?
    Regards.
    Pawel
    Exhaust manifold gasket?
