Cam timing
75% of the parts they supply are plain wrong or worse - counterfeit Then getting your money back takes weeks or months. 10 weeks is my record. Are during that they tried to tell me to cancel my paypal dispute or they would not proceed with a returns process. Obviously they don't know the law - good thing PayPal does.
They carry ZERO stock - when it says "In Stock" what that means is "Maybe we can get it drop-shipped to you, but if we can't we will send you some unbranded China ***** instead and try to charge you the same amount."
Awful, awful company staffed by utter morons who have ZERO clue about the products they are selling. There aren't many businesses which I go out of my way to slag off, but this is one of them. Sure they are cheap, but they are also greedy, lying d1ck suckers with utter contempt for their customers. Do yourself a favour and buy from an independent not these pricks
Originally posted by paulsf View PostThanks for the responses.
Re Autodoc, have found them great to deal with and they do seem to check my baskets for compatability before despatch so good service. The chain I bought is branded SWAG which is a Bilstein company so comfortable with the choice, especially with the prices Audi charge for the same parts.
Blue up the cam journals and turn the engine over and see where the witness marks are. If it’s pulling the cams together you will be able to see.
I would not trust any of that unbranded crap on AUTODOC though.
Yours matches OEM Number 077109120
Mine was an INA and tight like you say.
No problem to install and zero movement once tightened down.
https://www.autodoc.co.uk/ina/9920287
Hi Folks,
my friendly mechanic who is doing some work on my RS2 is concerned by how tight the new cam chain is when fitted, this is the one we ordered
https://www.autodoc.co.uk/swag/2143720
So, from the conversation above, how tight is too tight? Message I'm getting is no slack top nor bottom and he's concerned.
Any advice gratefully received.
Originally posted by maiks View Post
Sent from my Redmi Note 5 using Tapatalk
I will definitely check mine again before buttoning it up, but I think 10 links feels correct.
Ah ok, good ours are the same then just misunderstood the count method
The way you have done it seems ok to me, and I count 10, eg 10 places that a tooth could go into the chain. I need to confirm mine. I think mine is also 10.
Just to confirm this how I did the count.
I took the cam pulley back off after I lined it up and the marks looked good at the front of the cams.
Will be checking again when I get home
I'm at 10... Seen others at 11. Why is this not simple.
Originally posted by diesel des View PostYea it's an interesting 1. My chain too is quite tight. So, count from the 0 mark on the cam up to find vertical. 7 teeth Inc the zero tooth? Mark that point on your sprockets. Now count the links between the 2 new vertical marks. 9, 10 or 11.... I can't quite see the vertical position on yours.
Looks like a 9 to me cant get another look as away from home at the moment.
