Good news!
Head Gasket can of worms??? - Now chasing Boost Leaks!!!
Bad news is that I still have running issues which I am convinced is some seriously stale fuel. Only option now seems to be drain the tank and refuel with clean petrol.
I have been quoted £190 + vat to drain the tank. Anyone have any good suggestions for draining 20 litres of crap fuel myself? (How do I dispose of it?)
cheers
SteveThe Perfectionist
Originally posted by Fat Audi 80 View PostBad news is that I still have running issues which I am convinced is some seriously stale fuel. Only option now seems to be drain the tank and refuel with clean petrol.
cheers
Steve
Pop to TKmax and buy the cheap fluid transfer pump they sell. It's orange in colour with two long pipes. Remove the fuel pump cap in the boot and pump out into suitable containers. Get right down into the pump pick up area and you will find substantial crud there. Wipe out dregs with clean cloths.
However, unless your petrol is over 3 years old or you filled with E10 in the last year, I doubt that's the issue. The Coupe I recently bought has three year old super in it and it's running ok, if a little lumpy.Nothelle S2 Avant
Then dilute it with fresh stuff and use it in the lawn mower
- 1 like
Steve, there's no need to go into opening the tank or buying a pump. 20 Litres will fit nicely into a Jerry can and you can keep it for all those cleaning jobs you may have coming up.
To drain the tank, open up the feed line to the inlet manifold in the engine bay and use a piece of hose to direct it into your Jerry can. Pull the fuel pump fuse and feed 12 volts into the fuel pump circuit using a male lucar. The fuel pump will pump out your tank for you in a surprisingly quick time, just be ready to turn it off when the tank is empty so you don't run it dry.
Originally posted by s2driveruk View PostIs is not possible to just pull one of the rubber lines to the fuel filter and drain from there or does the pump lift the fuel to get there anyway?
I have a new fuel pump to go on, so will do that and probably drain the tank from there whilst it is out.....The Perfectionist
- 1 like
UPDATE!
Well it has been a while hasn't it! Life goes on and gets in the way of things, however slowly but surely I have worked through this list over the last 10 months:- Fuel completely drained and repaced - Same (New fuel pump and fuel filter whilst I was at it!)
- New POS Stages fitted and spliced into connectors - Same
- Replaced all 5 Coilpack with brand new ones (was on my to do list anyway) - Same
Once this was fixed the car still had a lumpy idle which I traced to a disconnected hose on the cam cover.
This week the S2 passed its MOT with No Advisories! Not bad for 29 years old and 190,000 miles!
My Audi fleet is now working and complete!
PXL_20220803_100541545.jpgAttached FilesThe Perfectionist
- 3 likes
Well done, good work!
I replaced all the inner pink bits on my injector plugs as they were all starting to break up.
Thanks John, how and where do you get them? Do you need a pin extractor?
Steve
Yes you need a pin extractor, I’ve got a cheap set and a couple of proper ones (but you can do it with a paperclip once you get the hang of it). The plugs are called Junior Power Timer or JT. Alex can supply genuine ones I think, or eBay which seem to be copies (or maybe they don’t make them the same as they used to.)
- 1 like
