Service Parts
Timing Belt Parts 3B
Timing Belt Parts ABY
Braking Parts
Suspension Parts
Drivetrain Parts
Electrical
Cooling System
Engine Bay
Other
034 115 615 A | Oil Filter |
191 129 620 | Air Filter |
8A0 819 439 | Pollen Filter |
058VAGF5DPOR or 101 000 016 AA |
Spark Plug |
N 043 854 1 | Sump Plug Washer |
115 VAG 421 | Synta Gold Oil 5 litres |
G 00 2 000 | Hydraulic Oil |
054 109 119 G | Timing Belt |
034 121 004 X | Water Pump with Gasket |
N 010 143 2 | Crank Bolt |
034 903 137 | Alternator Belt |
035 260 849 C | PAS Belt |
054 109 119 H | Timing Belt |
054 121 004 AX | Water Pump with Gasket |
034 105 229 A | Crank Bolt |
078 109 244 F | Idler Roller |
034 903 137 B | Alternator Belt |
034 260 849 E | PAS Belt |
895 698 151 | Front Brake Pads |
895 615 301 D | Front Brake Disc |
895 615 601 A | Rear Brake Disc |
4D0 698 451 A | Rear Brake Pads |
321 615 141 | Guide Pin Bolt |
Ford 6141147 / 6141148 |
Rear Caliper Return Springs |
Ford 6141154 | Rear Caliper Guide Pins |
893 407 181 | Wishbone Bush (Forged) 45mm |
8A0 407 181 | Wishbone Bush (Cast) 35mm |
N 904 893 01 | Wishbone securing bolt (combi) M10x78 |
N 021 195 5 | Wishbone securing locknut M10 |
857 412 323 B | Top Strut Mount (blue) |
8A0 412 323 D | Top Strut Mount (green) |
8A0 407 465 C | Front RS2 Drop Link |
895 505 389 | Rear drop link |
895 407 365 A / 366 A | Front Ball joints (forged) |
8A0 407 366 | Ball joint (Cast) RHS |
8A0 407 365 | Ball joint (Cast) LHS |
N 010 445 7 | Front ball joint pinch bolt M10x45 up to chassis 8B-P-8000 |
N 034 778 4 | Front ball joint pinch bolt M10x50 after chassis 8B-P-8001 |
N 021 195 5 | Front / Rear ball joint pinch bolt locknut |
893 505 365 C/366 C | Rear Ball joints |
N 010 445 7 | Rear ball joint pinch bolt M10x45 |
Part Number | Description | Notes |
857 199 415 B | subframe Bush (Front of subframe) M10 | up to end of 1992 Model Year |
857 199 419 B | subframe Bush (Rear of subframe) M10 | up to end of 1992 Model Year |
N 905 569 02 | Securing bolt M10 x 75 | up to end of 1992 Model Year |
823 199 347 | Securing washer M10 | up to end of 1992 Model Year |
8A0 199 415 B | subframe Bush (Front of subframe) M12 | from 1993 model year onwards |
8A0 199 419 A | subframe Bush (Rear of subframe) M12 | from 1993 model year onwards |
N 905 037 02 | Securing bolt M12x85 | from 1993 model year onwards |
N 905 808 01 | Securing washer M12 | from 1993 model year onwards |
441 498 203 A | CV Boot kit |
016 409 399 B | Rear Diff oil Seal (rhs) |
VAS-5051/2 | Diagnostic Cable |
4A9 953 503 | Rear Wiper Switch |
445 955 529 A | Rear Wiper Relay |
034 906 265C or Bosch 0 258 003 957 |
Lambda Sensor |
034 919 369 C | Multi Function Temperature Sender |
443 121 273 E | Aux Radiator Mounting Bush |
G 011 A8 CA1 | G11 Coolant |
069 121 113 Wahler 4116.87D1 |
Thermostat |
N 901 368 02 | Thermostat o-ring |
034 145 710 B | Throttle Cut off Valve / Dump Valve |
034 198 025F | Cam Cover Gaskets |
026 145 541 | Power Steering Pump Plug |
443 199 381 C | Engine Mount right up to chassis 8B-M-040000 |
8A0 199 382 C | Engine Mount right from chassis 8B-N-000001 |
443 199 382 | Engine Mount air con right up to chassis 8B-M-040000 |
8A0 199 382 D | Engine Mount air con right from chassis 8B-N-000001 |
443 199 381 C | Engine Mount left up to chassis 8B-M-040000 |
8A0 199 381 | Engine Mount left from chassis 8B-N-000001 |
443 199 382 | Engine Mount left air con up to chassis 8B-M-040000 |
8A0 199 382 | Engine Mount left air con from chassis 8B-N-000001 |
893 253 147 D | Exhaust Hanger (rear) |
895 601 165 | Alloy Wheel Centre Cap (Avus) |
443 927 817 / WABCO 899 760 510 4 | ABS Sensor Clamping Sleeve |
