Hi,
I hope not to have the wrong section. I have recently purchased a Coupe quattro 2.0 20v 160hp year 1989 engine code NM. I would like to swap with the S2 motor 3b. I have probably already found the engine in Ukraine. I am considering whether to use the stock wiring or do it again with a motorsport ECU. I wanted to ask you if you need to replace the gearbox or if the one already present is sturdy enough. Plus if you have any advice I'd be happy to
hear it.
thank you
p.s. sorry for my bad english
hear it.
thank you
