ignition problem audi 7a
  • Mikemul
    replied
    Any other ideas ? What checked/checked/replaced
    Wiring harness measured
    New sparkplugs mounted
    Compression measured 9/10bar at 1,2,3,4 and 5 have 8,5/9,5bar with closed throttle
    Fuel pressure measured 3/4bar
    Mapping checked
    Injector flow test done
    Crankshaft signal test done
    Checked firing order
    Sparks from plugs tested
    Inlet valve checked if they open
    Inlet gasket reassembled and additional liquid gasket used in between
    Temperature sensor connected
    Oil pressure sensor connected
    Engine timing checked
    Ignition time controlled with timing light
    changed injector at nr 5
    cylinder 5 is sparking while the engine runs on the other 4 cylinders
  • Mikemul
    replied
    Originally posted by Bowie69
    Why did you have to swap intake?
    because the 7a intake comes over the head and than I can’t use the ignition coils on each cilinder. That’s the only reason
  • Bowie69
    replied
  • Mikemul
    replied
    Any other ideas? I did a flow test and all injectors give the same amount of fuel and sprays good. I have remove change the 7a intake for a s2 intake but there is no turbo on it so is this the problem? If there is a spark
    and fuel there is firing???
    This gallery has 1 photos.
  • Mikemul
    replied
    Originally posted by simons2
    Number 5 injector bad or stuck open ? Have you tried swapping that injector with another one and seeing if the fault moves ?
    Yes have try swap but the same problem on cylinder 5 any other ideas?
  • Mikemul
    replied
    I haven’t try that lets give it a try
  • Mikemul
    replied
    Originally posted by larsaskogstad
    Headgasket issue? or?
    Have you checked the compression on each cylinder , both dry and wet ?
    yes all the cylinders between 10 bar only 5 is little lower it’s about 9 bar all plugs dry and black only cylinder 5 wet.
    there are new pistonrings on it and new headgasket
  • simons2
    replied
  • larsaskogstad
    replied
  • Mikemul
    started a topic ignition problem audi 7a
    hey guys, i have a difficult problem on my audi 7a engine. it is build with pinbobines and a standalone ecu. everything is correct connect. i have test the hole wiringloom and the injectors sprays and the sparks spark. the firing order is 1-2-4-5-3. the engine is starting(very bad) and runs on 4 cylinders. all sparkplugs are black only cylinder 5 is wet. this cylinder run not. i have try to change the plugs and the bobines but no different. when i crank when all plugs in the bobines on top of the cylinderhead they spark all the time? so any suggestions? fuel pressure about 3-4 bar 123454.jpg
