Removal tool for oil pressure switch
  • Removal tool for oil pressure switch
    Hi tried to find the OEM number for theremoval tool/socket for oil pressure switch ,, the big one. ABY engine.
    Part number. 035 919 561
    Best Regards
    Crows foot spanner or bend an old spanner. I think it's 17mm from memory.
    Wr Ur Quattro in restoration
      Yes. 17mm. This is what I made. You will see I trimmed the internal part of the spanner so it fits the nut snug. I use a long bar to give it a whack when undoing. Works really well.
        I have a great tool for it.. when i have the room for it .. i can borrow the original VAG toool and its some kind of socket ... so thats what i nedd , but thanks for the advices ..
          I think the VAG tool is effectively a crows foot socket, I could actually do with getting a set of them as it's one thing I don't have in my tool kit, we do have them at work. It's so rare that I have to use one at home though, normally I do something like Dave's solution and modify a spanner, I've got quite a few 'special' spanners I've made for job's on S2's over the years.
          The sender can also be undo with a stubby 17mm spanner but it's a fiddle.
          1989 B3 2.0 3A 80 quattro. Long term project.
          1992 C4 100 2.8 Avant quattro, daily driver.
          1995 RS2, MTM K26/7, 380 BHP conversion.
          1997 C4 2.8 30V quattro, currently breaking for spares.
          1991 MK2 Golf G60. For sale.
          1990 Corrado G60. Looking sad.
            When you turn the key as far you can without starting the car ,,, are the warning light for oil flashing ? It should be flashing since there is no oilpressure .. .correct ?
              No. Only the battery light on with key in that position.
