Looking for a bit of assistance if I may.
I have a replacement G40 sensor that I need to fit which is a generic part with no plug. I was hoping to locate the correct 3 pin plug that is pre-wired to a three core wire that I can solder to the new sensor but I can't seem to find such a part anywhere. Does anyone know of any suppliers that would sell such an item? The plug im after would be the same as the original, which has the part number is 443906247.
The old plug from my faulty sensor has fallen apart (as per the photos below), probably due to the heat cycles and age, so a new one is required.
Ideally I hoped to fit something that is as close to original as possible, but I am open to suggestions if anyone has found alternative solutions they want to share.
Cheers.
Cheers.
