S2 aby, mfts f76
  • CQ20VTurbo
    • Aug 2023
    • 5
    S2 aby, mfts f76
    Hello everyone,
    I need to dig up a very old thread about the MTFS F76:
    Originally posted by turbofan
    + - Voltage supply, term. 15a (battery voltage)
    C - Actuation of coolant temperature warning lamp (overheating) (termoswitch)
    R - Air conditioner safety shutdown (termoswitch)
    T - Actuation of coolant temperature gauge (9,8 ... 10.4 V from dash)
    It's about thread #6 and the information above, in the following, LINK =>
    https://www.s2forum.com/forum/techni...rs#post2155290
    In my case, the ABY engine is installed in the CoupeQuattro Type 85.
    After a long search, I found some important information about the F76 here in the forum, - but a few questions remain.
    What exactly is connected to PIN 1/T on the ABY F76, and what potential is there?
    • Ground
    • or
    • +9.6-10.4V?
    Where does the voltage come from, where is it provided ?
    • Does the voltage come from the Minicheck / KI ?
    • or
    • is it provided internally by the F76, and then simply passed through to the Minicheck / KI via PIN 1/T ?
    After all, the F76 already receives +12V from Si 12 via PIN 3/+. It's conceivable that it converts this to +9.6V-10.4V.
    But I'm not sure...
    Perhaps you can help me with the information I need?
    Greetings from Germany
