Also, there's a bundle of earth wires bolted to the rear LH corner of the inlet manifold, near the dizzy, everything to do with the engine management is grounded on the bolt so check for corrosion and breakages there.
Intermittent power loss
- 2 likes
Great - thanks so much again. Car is 1990 RR UR Quattro 20v. Going to check all the wiring in that area. Is there a diagram or photo anywhere of the coil low voltage connections, I have removed and cleaned the HT side but the opp end looks like a big plug. Apologies for all the basic questions but I am also mech eng not electrical and whilst I can follow logic, electrics are not my forte
Originally posted by predding View PostHi John, I sent you a couple of messages re the MAF...
