whats my maximum RPM ?
  • MGaz
    • Feb 2008
    • 698
    just wondering what my max recommended RPM would be on my 2.5 GTi engineering 5 Cylinder?
    i know its a 2.5 now, so 'theoretically' the 'safe' MAX RPM should be less. but i'm wondering if its ok to rev much harder? , what with it having forged internals and solid lifters.
    @ the moment i'm guessing the limiter on a 'standard' 2.2 is 'suppose' to cut in at under 6400rpm (looking at the rev counter)
    yet its Actual cut in seems to be 6000rpm and bounces off it even lower than that.
    It catches me out a lot because its not even on the red! .
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • aronmatic2
    • 2129
    • Country: Hungary
    i used 7300rpm on street and 7800rpm on dragrace with hydraulic lifters. 7800 is not so healty.
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
    • Albert
      • 1500
      • Country: Poland
      do you have 92.8mm or 95.5mm crank ?
      AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
      • MGaz
        • Feb 2008
        • 698
        i believe its not the 2.5 diesel crank, but instead a custom 94mm made by GTi engineering
        and bored to 82mm. (i think)
        also runs Ported and Polished Head with 41mm Inlet Valves & 35mm Exhaust Valves. (i think)
        10.5:1 Comp ratio
        supposedly Runs 170bhp on the standard CAM, & Standard Exhaust.
        is that any help?
        Schrick 272 cam
        ITG filter
