Yeah I get your point.
I guess there's very few people that wants to be guinea pigs with their beloved S2's.
Those STR manis is cheap as chips though, so if one isn't bothered with perhaps changing the EM a little sooner than expected then one should be OK i guess.
We could all sit here and debate about these things to eternity, but it's the IRL performance/durability that really counts IMHO.
STR exhaust Manifold
the thing is that all manifolds crack,but if they do in 150.000Kms or 20.000Kms is what makes the difference.RS2 manifold on OEM map which is quite lean,it cracks after 120-150K kms and i suspect that the EVO would last as long.If you get a tubular manifold though,it will barely last 20-50K Kms because of it's thin structure and weldings.
I got a promice from my mechanic at some point that he could make a manifold for me,tubular,his design,out of thick metal tubing non stainless steel and it would last as much as 80K kms,or if it didnt he would fix it for free...Didnt believe him! haha,so im sticking to EVO for my next upgradeLeave a comment:
Yeah well, that's the tricky bit as I understand that most cast design EM's are prone to crack, that goes for RS2 OEM and I guess the EVO too.
Oh, I'm not _that_ technical as those guys were that I referred to, so I can't really add any insight in the discussion
yes you are right.important for me is not to crack,at least soon,but as im not so technical myself,i would go for something that wouldnt need changing in the future.Problem was when i rebuilt my engine,that the EVO manifold wasnt ready yet....Leave a comment:
This manifold has been discussed over at nordicaudi, some guy in norway. I believe, is running that one and is well happy with it.
The debate about the design of the runners got pretty lively and I think the conclusion was that due to the 5 pot engine design and the way the gas pulses in such an engine it didn't really matter.
It got very very technical over there, but as I said he was happy with it and it had not cracked so that's what really matters I guess.Leave a comment:
I think Bram had bought one and didnt like it all that much,plus he had to modify it for the wastegate to sit.If it were me i would look away.All 5 runners connecting into 1 bigger is not a good idea.Perhaps the OEM rs2 one could be better.Easily for 380hp.But if you end up getting the OEM,buy the RS2 EVO for the same money and you are good for 500hp!Leave a comment:
I did a seach on here (str manifold) , and found a thread, guys done a bit of a write up, pics of it when it arrived etc, hes fitted it, but doesnt comment on how it performs....Leave a comment:
I looked at this myself, for the same reason.
Looks pretty good in the pics and sounds OK, but why is it sooo cheap...?
Guys,
can you tell me if this manifold is any better than the standard one on my ABY?
im doing a RS2 conversion, aiming for 350-380bhp will this manifold be upto the task?
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVWTags: None
