Catch tank - how does it work?
Adding a catch tank is straight forward, and very beneficial. I used a beer tin on my old Mk II Golf GTis. I will do something more elaborate with my S2 when I start on the engine mods. -
Thanks Paul
Sounds like a very beneficial mod for the cost involved.
Do we have a definitive 'how to'?Leave a comment:
There are three main benefits with a good catch/cyclone tank -
1. Reduced air temp with all that hot oil vapour removed => less chance of knock for same operating condish
2. Cleaner air without all that oily crap => better burn => more performance
3. No oily gunge building up in the intercooler and intake plumbingLeave a comment:
and this is what I found... http://www.s2forum.com/forum/showthread.php?t=28625
I'm still interested to know what the benefits of this system are...Leave a comment:
Do you still run the cannister as i know stu and james/terry have done away with it and i'm in mixed views as tbh I need all the space under the bonnet I can getThere are quite a few threads on this if you have the time to search, including 2 I did in the last couple of months.
Basically the only issue is the carbon canister plumbing as everything else gets replaced. The fix is to re-route the fuel tank breather in the boot.
Overall it was all in all very easy to sort.
Overall it was all in all very easy to sort.Leave a comment:
Not sure if this is the right place for this one, so Mods please move as appropriate.
Next off, this thread is really for the 'mechanically/technically challenged', like me...
I gather from the thread on the Mocal catch tank, that it :-
eradicates the crappy standard breather system; and
is for catching oil vapour instead of using the PCV hose.
So,
what does the PCV hose do?
what is it connected to?
where does the oil vapour come from?
how is the catcher connected up in place of the PCV hose?
what are the advantages of the catch tank vs the PCV hose?
Any diagrams or pics would help I'm sure.
Thanks in advance
Tags: None
