Turbo identification help please K26
  • lini
    replied
    Since there are diferent opinions I'll try both just for the sake of it. Now i'm getting curious.
    From the last link I checked the numbers and it's clear that I have K26 67 if the turbine is always the same only compresor is diferent. And the turbine number is 6.
  • 20vQC
    replied
    good info mate thanks a lot!
  • rs200
    replied
    maybe this link can help you..
  • 20vQC
    replied
    Originally posted by rs200
    revo sms use the same turbo like mtm for 303hp- but different name.
    friend have a original sms turbo and I have mtm turbo.
    we do some measurements they are the same in all cases.
    now I drive a revo sms program and MTM turbo- works perfect
    my turbo is:
    number: kkk 26 14-70
    cold side 3526-101-5160
    hot side 5328-101-8362 G
    20 471 90 50 this is a number on a blue plate
    on revo sms 303hp (original) there is no identification number just revo sms on blue plate and off course KKK sign on hot and cold side
    I can't find any info of your mtm turbo mate... do you have the compressor and/or exhaust map available? Do you have an idea which cars used came from factory with it?
  • porkkis
    replied
    K24 and K26 are turbo family designations. They do not by any means identify a turbo.
    MTM303 turbo is what some people call a "small hybrid". It's RS2 cold side mated to a 220hp Porsche turbine. A stupid combination if you ask me.
    I have never figured out why the factory calls the RS2 turbo a K24 as there is absolutely no parts from K24 series in it. It's all K26.
    If anyone has an affordable spare water cooled K26-6411 turbo from a 10V engine, I'm interested in buying it.
  • rs200
    replied
    Originally posted by lini
    If the K26 from 220ps posrch is wors than k24 I think I'll try to run that chips on K24. I'm interested in the lifetime of the K24 then. Do not know any walues cause I didn't try that chips jet. Engine is sitting beside the car waiting for my time. I think it will be done in two weeks.
    when I change the ECU (revo sms) in the car. first I go to thy the car on k24 turbo. It was a big different. have a perfect spool but not enough power in high revs.
    and very linear acceleration .
    then I put k26 and it have bigger turbo hole but when they kick it is amazing filling.
    my advice : use k26
  • rs200
    replied
    Originally posted by 20vQC
    Cool! then you have the K26 from the 220bhp 944! how much absolute pressure allows you the mtm chip with that turbo? How about the lag? Thanks Lini!
    BTW, Does somebody know what kind of turbocharger uses the SMS Revo and Revo-S models? I know are K26's too but dunno the codes. Revo's have 303bhp and Revo-S 375bhp. The turbo from the Revo-S version might be a good upgrade I think.
    my turbo is:
  • lini
    replied
  • 20vQC
    replied
  • lini
    replied
    Numbers speak for them selves:
    K26
    atl.nr. 86 033 1080
    ausf.nr. 5326 970 6720
    Thanks!
    PS this turbo is watercooled.
  • 20vQC
    replied
    I have read all the topics considerink KKK K26 and there seems to be a general opinion that K26 flows les than 24. I have a K26 from porsch 944 and mtm ecu with 303hp. Would you recomend then runing this ECU with K24 or K26? If the K24 boosts sooner and has more flow then it would make sence runing that remap with stock turbo.
    Hi lini! Which k26 are you using from the 944? 220bhp or 250bhp??? I red somewhere we could use the turbocharger from the 250bhp version for a turbo upgrade on the 2.2t and avoid the 220 cuz it is like going one step back from the k24-7000. I'm afraid all the 924/944 turbos are only oil cooled unfortunately, so the time between oil changes may be reduced. I have this information about the 944 turbocharges used on the engine 951 (2.5 litres 4cyl), which one do you have???
    KKK Porsche 944 Turbo 1985- ??
    (2.5) 220bhp K26 53269706710 951.123.131.00
    (2.5) 220bhp K26 53269706720 951.123.131.02
    KKK Porsche 944 Turbo 1989-91
    (2.5) 250bhp K26 53269707041 951.123.131.03
    (2.5) 250bhp K26 53269707042 951.123.131.03
    Cheers!!
  • lini
    replied
    PS sorry for opening an old topic but I want to have a car on the road while I save founds for proper tuning.
  • Audi Parts Guru
    replied
    Originally posted by Sir Buff
    http://eng.turbo3k.com/catalogue/d-1396/
    Compressorwheel: K27-3060G
    inducer 45.6mm
    exducer 76mm
    Not good for 400hp I think. The inducer is smaller than RS2 one (47mm).
    Hence why there are two fitted to the Porsche engine in question
  • Sir Buff
    replied
    inducer 45.6mm
    exducer 76mm
  • kwlw
    replied
    Dunno I'm late or not, but it is ancient Porsche turbo, reference number 935.123.013.00.
    I may be wrong, but it should be capable of at least 400+hp if it is what I think. Main reason - it is basically K27 turbo, has K27 cold side wheel and #10 hot side...
    As it is ancient turbo - expect loads of turbolag with it.
    You can (ask to) measure compressor intake inside diameter (hole in the turbo through which air is sucked). If it is at least 57mm in diameter - then it is some kind of racing turbo capable of lots hp and lag.
    Sau
