Turbo identification help please K26
  • nemilosu
    replied
    here http://www.sjmautotechnik.com/troubl...turboparts.htm
  • avants2turbo
    replied
    Originally posted by Audi Parts Guru
    Definitely no, sorry
    cool thanks
  • Audi Parts Guru
    replied
    Originally posted by avants2turbo
    so... in your opinion, is it any use for an s2?
  • avants2turbo
    replied
    Jamo, KKK in Germany currently produce 24 different K26 compressor wheels for various different applications. Therefore it may well be that there are some K26 compressor wheels that ultimately will not produce quite as much power as some K24 compressor wheels, simply by virtue of their particular design and application. However, as I said in my earlier post, in general, a K26 compressor wheel will produce more power than a K24. Hence why a popular upgrade for the S2 is to fit an RS2 turbo.
    Standard S2 turbo has a K24 compressor wheel
    Standard RS2 turbo has a K26 compressor wheel
    With regard to the Porsche unit in question, it is listed as a K26 turbo. This in fact has a K27 compressor wheel fitted to it, and KKK currently produce over 70 different variations of the K27 compressor wheel.
  • Audi Parts Guru
    replied
    Originally posted by Jamo
    Ring MRC and speak to Mihnea and see if you still feel that way
    It's a common misconception that a bigger compressor wheel will make more power.
    This is not the case as the wheel design must be taken into consideration.
    For instance there are new wheels available for the Garrett GT turbo's that are smaller than the originals that make more power.
    replied
    Unfortunately this will be of no use to you as this particular turbo would be one of two turbos fitted to that Porsche engine. It's a flat 6 engine of 2.65 litres, therefore each turbo will be responsible for 3 cylinders of just over 1.3 litres, which is very different to a 5 cylinder engine of 2.2 litres
    Jamo, in general a K26 will make more power than a K24 by virtue of the fact that it's a bigger compressor wheel, however the downside is more lag
    Most straight K26 make 300bhp same as a K24 except with a lot more lag.
    They need to be a hybrid of housing and wheels to get decent performance
  • Audi Parts Guru
    replied
    I know ive just asked the question, but ive just done some digging....
    found a website called www.turbo-product.com
    the website lists turbos, by manufacturer of turbo, or by car
    so i looked at the KKK section and found the AUSF-NR 5326 970 6024 is a porsche part no. for a turbo for the 1982- 956 (635BHP Le Mans car) 2.6L turbo
    not sure if its any use to me still though.. lol
    replied
    K26 turbo's I would advise to steer clear of. They make less power than the stock K24 but with more lag.
    The only decent one is the K26/K27 hybrid
  • avants2turbo
    replied
    Originally posted by K Simmonds
    Your going need to post up some photos to get an answer I expect.
  • K Simmonds
    replied
  • avants2turbo
    started a topic Turbo identification help please K26
    Have found a turbo im interested in, and am interested if i would be any use to me?
    its a KKK K26
    the markings are as follows
    Grosse : K26
    ATL - NR : 87 262
    0427
    AUSF - NR : 5326 970 6024
    im looking at putting this on an s2 avant with a RS2 rep manifold and other RS2+ bits
