Boost leak testing?
  • iib3327
    • Sep 2008
    • 87
    Boost leak testing?
    right have had a boost leak test kit made up and findind it strange that i have to block the vacume pipe off to the wastegate as it bleeds off very quickly.. should this be the case or is there a problem? i've got the top boost pipe/maf end and breather blocked off but had to block the vacume to the wastgate to hold pressure.
    here's a pic if this helps.. (dont ya just love s2's)
    cheers again peeps..
