Engine mounts (bolt in) for my v8 swap or 5 cylinder:
  • Josh-stateside
    • 741
    I'm having these engine mounts made that use audi allroad transmission mounts as the rubber mount. They are small and compact and strong. My mounts from 034 are for a 5 cylinder application and so I made a jig of my old coupe quattro and a jig from my sedan and drop the front of the sedan off at the welder's shop. Basically what you see would allow either a 5 cylinder or v8 block(with 034 mounts) to mount into a b4 v6 sedan chassis.
